30K mile service, dealership stories wanted
RRaptorscallion0331
RRaptorscallion0331
Colin
Well I got it to the dealership, they were the only ones who could get to it today… but for “issues” such as the boost leak, they say they take 24-48 hrs to diagnose the issue.. so I will have to take it back to them on Tuesday to address that
RRaptorscallion0331
RRaptorscallion0331
Colin
Here’s what I’m getting done for the 30k service
Ford Ranger 30K mile service, dealership stories wanted IMG_0128
BrrRaptor
Raleigh Nc.
Ouch, I just did my 30k service myself which included all you listed plus front differential and transfer. Total was 265.00. Transmission pan drop was a pain but save big $$.
I would check diff levels when they finish. My rear diff was 1 qrt low
RRaptorscallion0331
RRaptorscallion0331
Colin
Thank you for the heads up! I’m slowly getting more comfortable working on it. Started changing my own oil after I got the rival engine skid and a ronin oil plug. What resources did you use for the transfer case flush? Or you’re just a gearhead and can figure that stuff out? Also, after they diagnose the turbo issue and the power outlet gremlins, I won’t be taking it back to any dealership so I’m okay with the final gut punch to my wallet, but I’m envious of your ability to do so much without that kind of cost.
BrrRaptor
Raleigh Nc.
I was blessed that my father was a B52 bomber mechanic in the airforce and taught me everything. If you can change your oil you can do your diffs and transfer case. Basically a drain plug and a fill plug. Fill until it starts dripping out the fill hole. Ranger manual tells you what fluid type and amounts.
Transmission is a little more involved but not hard, just messy.
This makes filling diffs/transfer easy!
https://a.co/d/0ePScGkU
RRaptorscallion0331
RRaptorscallion0331
Colin
Hey I really appreciate your insight, definitely going to order that!
last question, are there any unique sae or metric sizes that you’re aware of for the diff and transfer case (or any other maintenance)? I have mostly sae for larger sockets (1/2 - 1-1/4) and both sae (5/32-9/16) and metric (4 - 14mm) basic socket set and I buy them as I come across them (15mm for skid plates, 27mm for oil filter)
or if you know of a thread/resource where this is discussed could you please pass it along?
thanks again for everyone’s input
jordantii
Jordan
Tampa Bay
www.straptacademy.com
2025 RR
Here’s a small video of the turbo noise I was talking about, hopefully audio transfers with the video.
I have a similar if not the same sound. I'm going to pay attention to it and see if it's all the time or intermittent.
RRaptorscallion0331
RRaptorscallion0331
Colin
Yeah? Did you change anything before it started? Or just one day it began?
RRaptorscallion0331
RRaptorscallion0331
Colin
While I am quite the novice on engines, especially turbocharged ones, if they performed an upper intake cleaning (see above services ie: “GDI”, would that not have had any interaction with the air intake and turbos that they wouldn’t have seen or heard anything? I think I need to take a video of the boost levels because it has to correlate to a loss right?
BrrRaptor
Raleigh Nc.
All you need for the diff/transfer plugs is a 3/8 drive ratchet. Goes right in the square hole in the plug.
jordantii
Jordan
Tampa Bay
2025 RR
So on my drive home this evening the sound is definitely the same as yours. I’m not sure what the stock boost targets are. But if this is a boost leak I want to find it. I guess I’m going to research “how to find a boost leak”… I hate the idea of going to the dealer for anything.
RRaptorscallion0331
RRaptorscallion0331
Colin
Sorry man, if I find out from the dealership what it is I’ll let you know, if you find out a way to fix it without the dealership please let me know
jordantii
Jordan
Tampa Bay
2025 RR
Yeah, let me know what they say. I’m curious if what we have is isolated or more common?
rocsteady
New Jersey
Federal LEO
Took my RR in today to get the seat recall done and see what they'd recommend for the 30K service. I was a little surprised after they did the oil and filter and rotated tires and checked a bunch of stuff (including the engine air filter and cabin filters that they correctly identified as not needing replacement as I had done them both a few weeks ago) that they didn't recommend anything else yet. Then the advisor printed the page below, using their "scheduled maintenance tool" and even set it to "severe driving conditions."
Ford Ranger 30K mile service, dealership stories wanted 1780704330964-pr
I've always found the dealer recommendations to be very pessimistic; that is, recommended things seemingly way before they should be done; or more often than most would need or want. This one is so far the other direction, I find it nearly useless. I know that technology of the mechanical bits and the lubricants is a far cry better now than it was in the late 90s, early 2000s, but 150,000 miles for driveline fluids?
Anyway, I think I am going to wait until between 40-45K to service the 4WD stuff and probably even have them do spark plugs at that point as I have had bad experiences with waiting on the "long life" plugs and then they don't want to come out of the head. Figure if I do it this way,, I'll have some breathing room before I have the shocks "serviced" at 50K.
