JustPassingBy
- Thread starter
- #1
The Ranger Tech Specs PDF posted on the Ford Media website has been changed since May 10. The most notable change from my perspective was:
Minimum Running Ground Clearance -- the 4x2 dropping from 9.3" to 8.8" and the 4x4 dropping from 10.4" to 9.3".
Departure Angle -- 0.7 degrees drop on departure angle for the 4x2, while approach and ramp over for the 4x4 increase by 1 and 1.2 degrees respectively.
There are also tweaks in some interior dimensions and some changes in the Technology section.
The two versions with the dates I downloaded contained in the file name attached below.
