A Stupid Trailering Capacity Question
Damphousse25
Ann Arbor, MI
2024 Ford Ranger Lariat 4x4 Offroad
I have a 24 Lariat. I know it is well overweight and Ford can never find out if I do it, but do you guys think I would cause any damage to the truck by using my Ranger to tow a 10,200 lb trailer with a 1,050 lb tongue weight about 200-300 feet. I just need to move it across my property. A quick trip down a path and then turn it 180 degrees. The ground is fairly solid and flat. Thanks in advance for advice.
No it won’t hurt it to move something like that a few hundred feet across your property.
‘Where you would get into some serious issues is trying to take it down a road at speed.
Good chance at roadway speeds it would start to push the truck around and could easily cause an accident.
Jockeying a 10k trailer at 5mph across a pasture or yard, parking lot etc. Isn’t going to hurt a thing.
Black Shadow
William
Richmond Va
2025 Ford Ranger XLT
CDL trainer
Lock the transmission into 1st gear when you move it.
You should be good to go. One of the issues with towing, is the stopping. Since you are only going to be going 3 or 4 MPH, that shouldn't be an issue.
Satex
Blake
San Antonio
2024 Ranger 2.7 Ecoboost
I can't argue with the other responses. Such a short distance at very low speeds will likely not harm any drive train component.
The bigger question for me though is the effect of all that weight on your suspension and/or frame. The circumstances surely minimize the risk ... you won't be bouncing around. However, at some point too much is just too much.
I'd do it if it was necessary and I had no other option. I'd feel like it's probably fine, but understand that it might not be.
OxygenMask
Phil
Eugene, Oregon
Not much outside of the recommended max tongue weight, still within payload, and without shock loading or the push during braking you'd probably end up with less stress than towing 5k up/down a fire road.
I remember those commercials!
Funny to think that a big block in those days made less power than our Rangers.... And got 10 mpg....
If you worry about the tongue weight, put some weight in the tail of the trailer.
Damphousse25
Ann Arbor, MI
That is actually a great idea. Throw some weight in the back and I have one less thing to worry about.
NM Mike
New Mexico
Under your circumstance, I’d say you are probably hood to go. The biggest risk for your situation would be a soft shoulder or soft spot that might shift the weight of your trailer onto your hitch. As long as you have hard dry ground, you should be fine.
Michael9218
Michael
Woodstock, Ga
2025 Ford Ranger XLT 2WD
I would also say to beware that your insurance will likely have an exclusion for operating beyond the stated capacity.
