Advanced Tow brake controller + on-board trailer controller
mikeytreehorn
North Lake Tahoe
TBD
Hi there! Long lurker, first poster.
I'm considering a ranger that has the Advanced Tow Package, which I understand includes a factory/mopar proportional brake controller.
I have a trailer with an onboard brake controller (Tekonsha 902502 specifically). I love this controller ordinarily, since it doesn't require the tow vehicle to have a a brake controller - just a 7-pin connector.
My guess: I could/should NOT use this controller when an onboard brake controller (such as advanced tow) is operative. Could anyone with a better electrical understand confirm, and/or suggest if there is a way to bypass or disable the onboard controller (allowing use of the trailer controller)?
My assumption is when towing with this vehicle or any other with its own brake controller, we'll physically take the Tekonsha out of the loop and wire the trailer directly to the tow vehicle 7-pin. Thanks!
OxygenMask
Phil
Eugene, Oregon
2025 Ranger Raptor, 2012 F350
You are correct, you shouldn't use both. Odd to have a controller on the trailer but I can imagine situations where it's a neat idea.
What "I* would probably do is install a switch on the trailer to bypass the trailer mounted controller when connecting to a vehicle that has a controller.
surfstar
CA
2025 Lariat 2.3 FX4
Just running across this post and wanted to add/clarify - the Tekonsha Prodigy wireless brake controller can simply be "unplugged" when towing with a vehicle that has a hard-wired brake controller. The Prodigy is plugged in-line on the trailer. Take the 7-pin from the trailer, out of the Prodigy and plug it into the vehicle's 7-pin. Done.
