Aftermarket wheel/spare question
spellchek
earth
Searched but couldn't find an answer - those of you with aftermarket wheels, are you buying a 5th wheel for the spare as well if you are keeping the OEM tire size but have a different offset? I assume even in a pinch it wouldn't be ideal to drive on mismatched offset wheels. If so, any issues fitting a more negative offset (+25) wheel up in there?
RaptorME
Maine
Since I used the stock tires I just kept the factory spare. In a pinch I don't imagine the offset would cause an issue. For me I would just try to get the spare tire swapped onto the different offset wheel as soon as I could.
Mystic
Rusty
SoCal
'24 RR, '25 Explorer ST
Estimator
Offset won't really matter as far as stashing your spare underneath; the tire winch thing doesn't care what your offset is, just keep cranking until it's tight up in there. The spare slot fits up to 35s no problem...mine is 35x12.5 /+35.
I bought 5 wheels
Arsenall11
Maple Valley Wa
Mechanical contractor
same wheel and offset, off-road an pop a bead, much easier to get to it this way.
Ford Ranger Aftermarket wheel/spare question IMG_0247
I bought 5 KMC Canyon wheels (an extra to replace the OEM steelie spare)for my 24 RR which are +25 offset. With the 285 stock KO3's it fits just fine beneath the bed.
OxygenMask
Phil
Eugene, Oregon
The only vehicle I ever had a matching spare for was my Jeep TJ. Otherwise in 50 years it hasn't been a problem, although on 2 occasions off road I had to change 2 tires because I had a flat on the rear and the locker was not happy with a 35 on one side and a 225 on the other... :wink:
I wouldn't worry about offset, but I changed tire diameter so I bought a 5th wheel/tire combo for the spare. I also have snow tires and I matched the diameter/circumference of my spring-fall wheels and tires so I didn't need 5 of those.
RaptrJr
FL
I still have my stock spare wheel under the truck while running my +35 methods and stock tires. When I move up to 35's I have a 5th method that will be getting a 35 and going in the bed, and ditching the stock spare.
BoostCreep
Arizona
2025 Ranger, 4x4, turbo 4.
Different size tires effects the differentials and clutching as it deals with differing wheels speeds.
