25Dsand
- First Name
- David
- Joined
- Jun 12, 2025
- Threads
- 6
- Messages
- 75
- Reaction score
- 56
- Location
- Sioux falls
- Vehicle(s)
- 2025 ranger raptor
- Occupation
- usps
Thank You! The driver side tire would grab the front of the fender liner when in reverse at full lock. I was able to fix it by making a hole in the fender liner that lined up with the existing hole in the crash bar. Then I used a large push pin to pull the fender liner in closer to the crash bar. Then I added a small ziptie in the edge of the fender liner just below the 7mm bolt to pull the edge in closer as well. You can see both in the photo. That completely fixed my issue. The passenger side didn’t have the issue, but I did the same thing on both sides for conformity. That and my OCD. Otherwise, no other rubbing/issues at all.That looks pretty awesome. Any issues with rubbing with the larger tires?
I think these are the same vision wheels I have except mine are black and I have a lot more offsetThese will be coming off the GX470 and into the Ranger once I get around to leveling it.
Nice thing about having two rigs wjth the same bolt pattern
The white letters really pop18x9 Fuel Rebel +20mm offset in anthracite color. Tires are BFG KO3 275/65/18. Stock height, no level or lift.
Hmmm, running smaller tires than stock 285s on 18” wheels?18x9 Fuel Rebel +20mm offset in anthracite color. Tires are BFG KO3 275/65/18. Stock height, no level or lift.
ThanksLove it! Clean & classy!
- Details on wheels and tires?
- Also a “down the side” photo?
Any idea why ford.com claim these don't fit the ranger raptor? Is it the hub bore or the tpms sensors? Also I see you got the method center caps as opposed to the Ford Performance center caps? Any reason or just preference?Method 703 +35 17x8.5 hub centric. The 5 set off Ford.com
The wheels fit perfectly, hub bore is a dead match and reused my original sensors. The included sensor kit may be the issue, I don't think they were compatible with the RR.Any idea why ford.com claim these don't fit the ranger raptor? Is it the hub bore or the tpms sensors? Also I see you got the method center caps as opposed to the Ford Performance center caps? Any reason or just preference?
Mine are from Ford also. The tire shop tried using the supplied TPMS sensors but they wouldn’t work so ended up using my original ones no issue so that could be why they say they don’t work. Other than that they fit perfect.Any idea why ford.com claim these don't fit the ranger raptor? Is it the hub bore or the tpms sensors? Also I see you got the method center caps as opposed to the Ford Performance center caps? Any reason or just preference?
