Annoying headlight switch
LDHunter
Bob
NW Florida
Real Estate
Well.... Don't just blame Ford. GM has the same setup and it seems to be the dominant type of headlight control that I've encountered. Even my 2009 GMC pickup has the same setup so it's nothing new.
OxygenMask
Phil
Eugene, Oregon
2025 Ranger Raptor, 2012 F350
Does using forscan impact your warranty?
It should not affect your warranty at all - they are factory optional settings after all. Unless using forscan corrupts your car's software. It happens on occasion...
LDHunter
Bob
NW Florida
Real Estate
Well.... Don't just blame Ford. GM has the same setup and it seems to be the dominant type of headlight control that I've encountered. Even my 2009 GMC pickup has a similar setup.
alrashid2
PA
@Muffin1 did you find the FORScan change to be easy for this? Can you do it in the easier non As Built mode or do you have to go into As Built settings?
Thanks!
Muffin1
Muffin1
Rob
NJ
Thanks!
I actually don't remember it was a while back, sorry.
It was easy cause i got it done :crackup: You'll spot it in the plain text mode rather than the coded build if thats were it is.
Also there is a Forscan paper or writeup somewhere that shows a lot of the changes and you can check out Bronco6g forum there might be info there.
alrashid2
PA
Thanks Muffin!
ShadowDragon24
2025 Ranger XLT Fx4
Heavy Equipment Operator
dodge only gives you auto, marker, and headlights, no off aswell. our 2018 ram 5500 has an off, but our 2025 ram 5500 no off. only auto, marker, headlights.
