Anyway to tell if Ford Performance Tune has been installed?
chrisriner
Holly Springs, GA
Mobile App Developer
I spoke with Ford Performance and they said by looking at software version on pro call if the sw version has FP in it then it is the tuned software installed so you can confirm with that. Here is picture.
Ford Ranger Anyway to tell if Ford Performance Tune has been installed? IMG_0312
TurboRanger
Jack
Oakley , Comifornia
Retired Truck Mechanic
Do you need the display plugged in I don't want that in my face
Two does the dealer have to install it or can I just do it
Dingus83
Oklahoma
1. It does not need plugged in.
2. You can install it, it just won't have the FPP warranty of 3/36 on it.
TurboRanger
Jack
Oakley , Comifornia
The dealer I bought it from gave me a Lifetime drivetrain warranty :thumbsup:
Deleted member 12087
I bought my ranger raptor used and the ford dealer claims that the tune is already done on it. But I’m only getting 18-19 psi boost as well. Also this is what my pro cal is reading for the “SW”. There is no “FP” in mine. Is there any other way to tell if this tune is really done or not?
Ford Ranger Anyway to tell if Ford Performance Tune has been installed? IMG_8034
Dutchy
Melbourne
23Ranger Raptor
Hi guys.
FPP says this upgrade works on USA and Canada RR.
Technically this should also work on Australian RR too.
Can anyone confirm??
Driven
Louie
Nevada
Self Employed
My truck updated to 6.2 on me (left automatic updates on). I was concerned, but my SW is RB3A-FPG30A-JF still so I'm guessing I'm ok. Also didn't notice any change in performance yet. Are the ford updates compatible or are we supposed to keep it off auto update. Do you think my tune was affected at all? Just wondering, since you spoke with fp, if maybe they talked about that.
AlpineBike
Banned
Banned
Andrew
Waitsfield, VT
Hi guys.
No it doesn’t.
Your made in Thailand trucks don’t get the FP tune. They have lots of different components compared to ours.
The FP tune is only for USA built trucks.
chrisriner
Holly Springs, GA
They didn’t say about it. I need to 0-60 mine or Dyno then I would know for sure. I see the correct software. I am sure my dealer did it correctly and when they did I noticed difference in shift. However, I had to have the entire engine replaced, and I was a little worried after the fact if the tune was still there, although the tune is for the computer, not the mechanical engine parts so technically it should be there and the dealer said it should still be there and working. My problem is I’m not sure. I really feel the difference which is why if I did something like a 0 to 60 where I really were pushing it maybe then it would be noticeable not to mention the time would be different.
Dutchy
Melbourne
23Ranger Raptor
No it doesn’t.
Yes sure. But same motor / transmission combo and same ecu.
Love to hear from FPP on the possibilities.
AlpineBike
Banned
Banned
Andrew
Waitsfield, VT
No.
Parts are made in different factories.
You can not take the motor, transmission, or ECU out of a Thailand truck and put it in a USA truck.
brian_pham
Vietnam
Ranger Raptor 3.0 V6
Business Owner
if you want to rollback to previous version let me know i can help
TurboRanger
Jack
Oakley , Comifornia
If you ever take your truck to the dealer Return it to stock If the dealer ever does a update
you will Probably loose your tune
TurboRanger
Jack
Oakley , Comifornia
Recommend checking the boost. Stock boost for me WOT was around 18 PSI and with the tune it is around 22 PSI. You can see detailed PSI in MyView.
I saw 24 lbs with my FP tune
