Back door doesnt lock
Jpvert
J-P
Quebec, Canada
Ranger XLT
I have noticed that when i lock the door with the key fob and also with the lock button in the door my driver side back door doesnt lock but if i open the door the alarm goes on. Did this happen to anyone else and what to do? I just got my Ranger 10 days ago might take a trip to the dealer.
stuartmunto
Stuart
Perth, Western Australia
2023 Ford Ranger Raptor
Do both rear doors not lock or is it just the one door on one side?
Will it lock if you press the lock button twice on the key fob and do you hear a horn beep?
Joe T
Joe
Chicago, Illinois
It sounds like there is a problem with the LR door lock actuator. As new as your truck is, bring it to the Ford dealer and let them diagnose the problem.
The alarm is functioning properly if it sounds when the door is opened. It can sense the change in voltage and activate when in the locked position.
Does it have anything to do with the child safety locks?
Joe T
Joe
Chicago, Illinois
Just got mine and both rear doors won’t lock
Do they not lock with the door switch and/or the key fob? If neither work, bring it back to the dealer.
There are settings that can control which doors unlock with the fob or the use of safety child locks but if nothing locks them it doesn't sound like a setting.
Offroad Dave
Indiana
2024 Ranger STX
I tried all the settings and doesn’t look with fob or inside door locks. Someone else had same problem and they said it was a loose wire underneath the console. I found a way to manually do it with a black screw by the lock but then have to manually unlock with rear inside door handle. Good enough for now until I get to the dealer. Makes me wonder what other wires are loose lol
RangerDangerStranger
SF Bay Area
2024 XLT 4x4 in GreyBlue.
Cool Dude
I had to have both rear locks changed under warranty at the dealer. Both child locks didn't work and one was set to not open from the inside.
Joe T
Joe
Chicago, Illinois
Thanks for the update Jpvert, glad they got it taken care of for you.
SoutheastRangerRaptor
Thanks for posting this. My Ranger Raptor has always done this as well since getting it in March 2024. I've always meant to take it in and have them look at it. I will do that now.
Lifefoce
James
Miami
ford raptor 2019
That wiring harness issue is a known pain point on these new Rangers. Before dealer warranty work, I checked with an automotive specialist for peace of mind. For general car lock problems outside of warranty, I’ve used royallocksmithfl.com for quick key fob programming and they were very reliable in my area.
