Chirp/Click Behind Instrument Cluster at Low Speed
College Station, TX
Hey guys,
I’ve had my ‘25 RR for a few weeks now, and love it. I’ve been noticing a slight click behind the instrument cluster when accelerating at low speeds. It almost sounds like a really short cricket chirp. It seems to happen a handful of times when accelerating/decelerating at low speeds, but then stops. As in, it’ll happen a for a bit at first after starting a trip, but once I’ve been driving at speed for a bit, then stop at a stop sign, and start going again, I won’t notice it. It may be completely normal, but I haven’t heard it on other Fords I’ve owned, so I thought I’d ask y’all. Here’s a video of the sound. It happens 3 times, at 00:05, 00:12, and 00:22.
TaterSalad
Logan
Dallas
Mine is doing the exact same thing since the brake recal update and the dealer said they couldn’t hear it, then they could hear it, and that it was “normal” and couldn’t do anything about it.
It sounds to me like it’s coming from. The brake booster.
With the engine off, or on, before you take off driving, you can tap the brakes and it will do this after a second when you let all the way off. It only does it a few times, and you can exhaust that number of times before you drive away for that trip.
It will do it again once the power is off and the computer cycles
Dear god if you figure it out let me know it’s been driving me insane
ForzaFTW
Georgia
Mine does the same exact thing; seems to only happen when I first start driving the truck, and after a half a mile or so goes away until I drive it again.
speedtek
Joel
Iowa
Self employed
My 25 does this as well. It is definitely after starting the truck. Doesn't matter if it’s a cold start or warm. It appears something is calibrating, and not consistent on how long it does this.
danmoochie
dan
florida
retired Sales manager
I am getting this as well on my 25 XLT 2.7. I also get this random pop noise, which I am thinking might be the HVAC blend door actuators.... if only I knew where they were and how many LOL...
speedtek
Joel
Iowa
Self employed
Heard the noise in the garage after opening and closing the driver door. Noise is definitely coming from the driver side engine bay. My guess is it's a solenoid of some sort on the firewall that the sound is transferring into the cabin. Probably normal...
Surfergirl015
Sandra
Hey all,
So I have been having the same noise on my 2025 ranger Raptor. Everytime I went to drive it, it would do that cricket/clicking sound. It did it like clockwork. Brought it to the dealership and showed them a 30second video I had made and it did the noise three times in that short time. They were having problems trying to reproduce the noise, but told me keep an eye on it and to try maybe moving the steering wheel around. Tried that, still made the noise. Then one day, my husband and I finally got some of our upgraded parts in, so we could change out the charge pipes, air box, and intercooler, as we want to get it tuned. As we had the hood open, it made that noise. Engine wasn't running so you could hear it clear as day. It was coming from the brake system area. So we did an experiment and got in the vehicle and just pumped the brakes a couple of times and sure enough it made that cricket sound. Pumped the brakes again, made the sound. It is currently at the dealership and I was able to reproduce to them. The are currently on the ford hotline, but what it is looking like is the ABS hydraulic pump. I hopefully should hear back today, but my dealer had told me that they will like need to replace that part as it does it so much. I'll let you know.
tivct
Dearborn, MI
Ranger Raptor, Focus RS, Mach 1, F350
It seems to be standard operation of the ABS module. All three of my RR's did it.
