Crazy feature
Dino Jockey
Ron
Alabama
Not sure if this has been mentioned and if it has my apologies….
Today, I turned off my RR while in drive…. Sitting still of course….The shifter moved itself from D to P w/o me touching it…. Thought I was seeing things so I tried again to verify and it did the same. Not sure if it’s been noticed by anyone else but thought I would mention!
AMGRAPTOR
FL
2024 Raptor Ranger
Yes it is known. If you turn the truck off while it’s in drive, it’ll put itself in park for you or if you use the parallel park or backup feature it’ll do it when it’s done. Pretty cool
DaStockRR
Jeremy
It also auto shifts to Park if you stop then open the door before turning the engine off
stuartmunto
Stuart
Perth, Western Australia
2023 Ford Ranger Raptor
Yes it’s a known feature. You can bypass this by pressing the M button on the side of the gear lever when in neutral. This will keep the trick in neutral with engine off, or engine on and drivers door open
Dino Jockey
Dino Jockey
Ron
Alabama
Appreciate the feedback. Guess I live a sheltered life. 🤣🦖
Big Willie
Will
Chicagoland
2025 Shelter Green RR.
My 22 work f150 column shifter does the same as well.
gtomike60
Massachussetts
2025 Ranger Raptor,2006 Pontiac GTO,2012 RAM Power Wagon,2023Audi Q5
Collision repair and paint
Most vehicles with electronic shifters do this now ,not just Fords
