Dash Cam - which one?
diogomt
Brazil
🇧🇷 Ranger XLT
Nice install! I'll take a look at that camera model. I would be interested in how you think the video after you run it for a bit.
- Joe
It records at 2K, I'm very satisfied with it.
I've had some viofo dash cams before, the thing I liked most about this dashcam is how easy it is to connect to it, it's very simple and intuitive, you just open the app and tap on it, no need to press any button on the camera, open wifi settings, etc..
Raptortugal
Portugal
Ranger Raptor 6g
Here is mine, Kawa Mini 3 bought for 30€.
Ford Ranger Dash Cam - which one? ae_1743779420985
Ford Ranger Dash Cam - which one? IMG_20250417_164518
Ford Ranger Dash Cam - which one? IMG_20250529_144359
Ford Ranger Dash Cam - which one? IMG_20250529_144418
Ford Ranger Dash Cam - which one? IMG_20250529_144645
Raptortugal
Portugal
Ranger Raptor 6g
Indeed, it's exactly the same, same features.
I didn't know the Pioneer.
Alaska Steve
Alaska
I have the VIOFO A139 Pro 4k 2ch. I had the Viofo A229 in my last truck, but didn't like it's overall size on the windshield since I use the phone app to view the videos anyway. I like the A139 better. Here are day and night videos that I captured. I wired the cameras to the USB port, so the features while parked are not available in my setup. I'm also using the kdenlive open source pc app to edit the videos
Red Light Runner
Illegal Left Turn Into Pedestrian Walkway
smokinjoe64
SoCal
Really like the Nextbase 622 GW
  • Full featured, 4K, rear cam options, hard wired and more
  • Opted for cams for each vehicle instead of transferring/moving
RR shots...
Ford Ranger Dash Cam - which one? Library - 2 of 2
Ford Ranger Dash Cam - which one? Library - 1 of 2
>>Cannot advocate enough ➡ Dash-cams are a must have!!!
Regrettably, M3 got 'kissed' by a Hit-n-Run, uninsured, tailgating, rode rager, that chose to aggressively pass, swerve then collide with my vehicle narrowly missing a semi-truck trailer
skinnyjimmy
After reading some of the FB posts of people getting hit, what Dash Cam’s are people running or considering to run in their G6 rangers? Any pic;s would be appointed!
The thing to know is that almost every single dash cam on Amazon is actually made by the same 2-3 companies but just repackage or redesign the externals and software. They're almost always the same sensors. I've used 5-6 in my last car, and they all act almost identically. Redtiger, ROVE, and VANTRUE are all good if not basically the same. Do research and see which one has the features you want. I do recommend a three channel (front, interior, and rear camera) unit so you can get all angles if there's a crash.
fordgt
I am looking for a 3 channel unit, I really want to be able to see the front of the vehicle. I tried the interface available for Brazilian vehicles that allows for a front camera view on the infotainment screen but it didn’t work.
I guess the cameras are great evidence if someone hits you, aren’t they also great evidence against you if you are at fault?
skinnyjimmy
Sure, if you cause an accident and have a dash cam the footage can be used as evidence against you. But having the camera installed makes you instinctively more aware when driving because you know it can be used against you. Bottom line is don't drive like an idiot and you'll be fine 😂
smokinjoe64
SoCal
...I guess the cameras are great evidence if someone hits you, aren’t they also great evidence against you if you are at fault?
Negative - - dash cams are solely for personal use/sharing at your discretion and provide potentially objective 'proof' from false claims.
Soooo after cam incident view...if cam footage shows you're 'at fault,' no one has access to footage unless volunteered :wink:
holdreset
2024 Ranger Raptor (Totaled) 2026 Ranger Raptor
DDPAI Mini2X, so compact that you almost don't notice it's there
Ford Ranger Dash Cam - which one? {filename}
I have this exact same setup and it works great. The little wiretap kit I bought off amazon as well did the trick nicely to keep install clean. No issues so far.
RCMUSTANG
Ray
Los Angeles
1989 Mustang 2017 Fusion
Bought a FitcamX. It replaces the rear view mirror front camera bezel. Has t harness to plug into the factory wiring for power. Then you run the second cable for the rear camera. Have one from a different company for my Fusion and you can't even tell it's there. You can view through an app on your phone. I posted what it looks like in my build thread.
DrIanMalcolm
Anthony
Which wiretap kit did you use? I want to install my dash cam but unsure if there is anything in the mirror area I could pull power from. Any help would be appreciated!
holdreset
I used
YQMAJIM Dashcam Power... https://www.amazon.com/dp/B0D4HHSP7Z?ref=ppx_pop_mob_ap_share
then I tapped into the grey connector that supplied power to the rearview mirror. Taped it up, ran the little cord out side of the housing for the camera to plug into. I should note this only powers the camera while the truck is running which is fine enough for me.
**incoming pic of finished product**
Ford Ranger Dash Cam - which one? IMG_2129
it is prefect? No. I could have notched the backside and ran the cable that way but meh. I had it done and connected in minutes. Super easy.
DrIanMalcolm
Anthony
I used
Thank you!
