GLW
Missouri
I called 2 days ago and they said few more weeks. I canceled and going to retrofit some SS3’s
I ordered mine 3 weeks ago. They told me it would be 8 weeks. Shipped from StL yesterday.
Pirategrad
Clem
Austin, Texas
I ordered the yellow fogs a week ago and was down for the long wait. They shipped today and should arrive on Monday via USPS. Pretty surprised based on everyone else’s experience. ?
JohnCollier
St. Louis, Missouri
Ford Ranger
Are the lumen numbers worth it though? They look barely as bright as the stock fogs.
Diode Dynamics focuses on candela instead of just lumens because candela measures how far and intense the light is in a specific direction, not just how much light is produced. A high-lumen light can still look dim if it’s not focused right. The SSC1 fogs are designed to maximize intensity and beam control, so even if the lumen numbers seem similar, they’ll actually light up the road better where it matters.
c72k
California
Installed mine today. Bracket quality seems cheap (3-D printed mount) but light output much better than stock
Ford Ranger Diode Dynamics SSC1 Yellow Fog Lights installed IMG_1636
Ag3ntC00p3r
Product Manager
Hopefully installing mine along with remainder of skid plates this weekend. Looking forward to the new look.
GLW
Missouri
Received mine earlier this week and installed. Very easy installation. I wish I had had a stubby 1/4” racket (I do now!) as work area is a bit tight but doable. Bracket is plastic but fit well. Hooked up the backlight to aux switch two. Very impressed with the yellow fog output and the backlight when not using the fog. Looks really good with my signature lux grill lights that are connected to aux one.
HyperM3
Lawrenceville, NJ
Can you take a picture of what it looks like with the backlight? I didnt hook that up but now Im debating on it.
HyperM3
Lawrenceville, NJ
GLW
Missouri
OK, I like that. How hard was it to hook up?
Super easy IF you already messed with the aux wires and know where they are located.
After running the two leads up the sides I cut off the red connector and connected the two leads to an additional 18 gage wire that I attached to the aux two wire. Zip tied where needed to secure. No additional ground connection is needed as the ground on the fog connector also grounds the backlight. after gathering my tools together it took me about 15 minutes. I like using the aux switches so I can turn off lights if I want.
1 for grill lights
2 for fog backlight
4 for backup flood lights
6 for behind grill light bar
HyperM3
Lawrenceville, NJ
1 for grill lights
2 for fog backlight
Yeah, I already have the Aux6 being used for grill bar. Not sure I want to use an aux for the backlight. Can it be wired so its always on? Or would that mess with the actual light turning on?
GLW
Missouri
Actually just using the supplied connectors to hook into the side markers would probably take about 5 minutes per side as you are already in the area.
i really wanted to use the aux switches so that’s route I took but was tempted as the supplied connectors are impressive.
