Disabling Wireless charger
maxpetrock
2019 Ford Ranger Lariat
hey all!
Im wondering what the best way to stop the wireless charger from working. my phone doesn't really gain any charge from it and just gets hot in 30 min from being there.
I was thinking of creating some sort of block to stop it from connecting from my phone (maybe like some carboard with tinfoil in between 2 peices to stop it from connecting).
Has anyone else done this? or is there a way to disable this?
thanks!
Ag3ntC00p3r
Product Manager
Been wondering the same thing. I do get a good charge with minimal heat issues but wireless car play is so hit or miss I'd rather use that slot to hold the phone and use wired.
I'll probably cut a thick silicone mat to put in between the phone and pad.
jrRaptor
Maize, KS
Pull the fuse? Fuse #3 according to the manual. Not sure if it's shared with anything.
olefordguy
Craig
Alabama
For 2 years now on my truck, that's where I stack napkins from the drive thru. Never had the need to use the wireless charging pad, zero issues, even if I lay my phone on top of the napkins.
Cyrusblack
Banned
Banned
Pasco County
So are you saying that if you lay napkins on top of the wireless charging area and then lay your phone on top of the napkins it won’t charge? Sorry to lazy to get out of the Lazyboy and go check myself and besides I’m watching game 2 of the Rangers / Panthers ?
jrRaptor
Maize, KS
Forscan may be another option, perhaps?
Ford Ranger Disabling Wireless charger 20240524_234014
olefordguy
Craig
Alabama
Yes, granted the stack of napkins is probably an inch high. I keep all kinds of junk in that whole area, sticky note pads, pens, etc
jrRaptor
Maize, KS
does it also allow auto start/stop to be disabled ?
It's in there but I haven't tried disabling it. It doesn't bother me much since I use MyMode either way, so it's disabled through my settings. According to the spreadsheet posted in one of the threads, disabling in Forscan results in error codes or disabling other things.
Salty
Cyprus
Ranger raptor V6
Cheers thanks buddy
Or use a phone that doesn't wireless charge. Problem solved. :LOL: :clap:
fordgt
My Rokform case is not compatible with wireless charging. But I dropped it when I was on ladder from about 10 feet. Landed on the corner and bounced onto the other corners about 3 times.
