AmazonIs there a way to line the interior door pockets with something (felt?) to keep contents from rattling? Either a drop-in product or some way to apply a coating? Not talking about just the bottom surface of the pocket, but also up the sides. Thanks!
Purchased and installed these on my RR a couple months ago. Very satisfied. TufSkinz manufacturers high quality products. Made in USA too! You can get discounts.Is there a way to line the interior door pockets with something (felt?) to keep contents from rattling? Either a drop-in product or some way to apply a coating? Not talking about just the bottom surface of the pocket, but also up the sides. Thanks!
I'm not seeing them on that site. I wonder if they discontinued them.Purchased and installed these on my RR a couple months ago. Very satisfied. TufSkinz manufacturers high quality products. Made in USA too! You can get discounts.
Link:
https://tufskinz.com/
Stock - Front Passenger Door:
Installed:
Installed Rear Console:
Installation recommendations that worked out perfectly for me:
- Clean the surface with isopropyl alcohol and microfiber towel.
- Dry fit each Insert several times into their location before removing the backing from the 3M tape on the Insert for practice.
- You DO NOT want to try and remove an Insert once it has adhered to a surface.
You are correct! They don't have them listed in the regular Ranger products for whatever reason...I'm not seeing them on that site. I wonder if they discontinued them.
Thanks for the guidance. I just placed my order.You are correct! They don't have them listed in the regular Ranger products for whatever reason...
There are six Door Inserts. Three for each side. One for the front door, two for the back door.
I have a RR and found them by entering their site looking for Raptor products, then choosing Ranger Raptor.
https://tufskinz.com/collections/ranger-raptor-accessories
Hover over the Choose Options. You'll probably want a different trim color than the Orange that I chose of the Ranger Raptors.
Call Tufskinz if you're interested to make sure you get the correct product.
