JR RANGER
JR
Auburn CA
2024 Ranger XLT FX4 4x4
Not a ton of difference on pavement. Not as floaty I suppose. I've heard other people use the word "planted" before. Might not be everyone's cup of tea though. The cushier ride was nice, but not what I wanted overall.
Okay thanks I think you answered my question. I really don't want to loose the cushy on road feel but want to get a better ride off road. What I'd love to put on would be the eibach 8112. I know it would probably be overkill price wise.
JRRANGER
Jacdschu
2019 Ford Ranger 4x4 Lariat
Builder of Metal
Did your kit come with the bolts for the bottom front? Got my kit but I don’t have any bolts.
Please advise
Thanks
Sparky62
So Cal
Please advise
Thanks
I have the Pro-Truck 2.0 kit and yes, it came with the new lower bolts for the front struts.
Jacdschu
Builder of Metal
Well dang it mine didn’t. Do you by chance have the spec on them?
thanks
Aftermarket springs and dampers will never be smoother. They might maintain composure better with a firmer ride.
Chalk test your tires and run them as low as you can get away with.
Progressive springs will absolutely make the on-road ride quality smoother and better; putting the progressive leaf packs from the 5th gen tremors on non-tremor rangers was a popular upgrade for that very reason.
Sparky62
So Cal
thanks
Sorry, they’re already on the truck so I can’t confirm the size.
Call Eibach support and I’m sure they’ll send you some.
Jacdschu
Builder of Metal
I did that. Should have them tomorrow. Needed a plan B.
Thanks
California
2024 Ford Ranger XLT FX4
That was very helpful. I've been back and forth on ordering these for various reasons, one being my mechanical skills are...limited.
Thank you!
I can second that the lower bolts are hard to remove. I ended up using an air hammer to knock them out and using that tool it was easy.
Jacdschu
Builder of Metal
I finally got mine installed. It raised it 3”.
I think I need to lower it down to a 2” raise.
What did anyone else come up with?
Nuke
Jax
2024 Ranger 4wd Cactus Grey
2024 2.3 4wd is 2.5 to level front
Chaz6G
Charlie
San Diego
2024 Ford Ranger Lariat FX4 2.3
Design Engineer
I have a 2R kit arriving next week. Anyone have issues with OEM UCA at 2-2.5”?
Wolfman00
matt
crofton md
2024 xlt
how was popping the rears out? looks like the fender liner would make it a pain?
Matt77
Minnesota
24 Ranger xlt
Cheated, used a 1 1/2" hole drill bit to make an access hole for a socket. Super glued a piece of black plastic over it when I was done.
buzzleo
LA.....lower Al
Not yet an owner
The only tricky part for me was getting the stock shocks out. Specifically, the bottom 2 bolts didn't come out with a hammer. Or putting a floor jack under them. The instructions did mention they might need to be heated up. I don't have a torch so I used a grinder and a recip saw to cut the bolts and/or the tabs they go through. Kinda stunk wrecking them, but I was kinda committed. Like I said though, I'm far from being a real wrencher.
I actually lowered the height of the eibachs a little. They didn't specifically recommend upper control arms unless you go higher than the way they send them. (Level)
Hope this helps.
So the 2 bolts that connect the shocks to the lower control arm are pressed in to the lower control arm?
