Fog light options
If these could be aimed I would! The aiming mechanism for our fogs are attached to the OEM housing. These are bolted into the 3 bolts that the factory housing used, but with no aiming ability. I’m sure you could fashion some spacers of some sort if really needed.
That's actually what I was thinking, with some small washers.
HGHVLTS
24 Integra Type S, 65 Mustang Fastback, 71 Skyline 2000GT, 72 Celica ST
Electric System Operator
I ordered a set and they are due in this week.
Would like to see these once you install, would like to see actually Fog light options. Not to mention if Moustas has done anything to fix the bracket for the USDM market.
scuba mike
Southern Calif
Hvac Job Foreman
ok just finish installing the passenger side BD fog light not bad.. ( it was only a 102F here) only thing i can say is watch there is a pass and driver side bracket and the pins for the elec connector i did place a little elec grease and some tie straps. there is a very small gap around the lights not bad..
Ford Ranger Fog light options 1787699763255-gx
Ford Ranger Fog light options 1787699830012-5
the brackets are cast with a d and p for what side they go on.. little easier with tires turned outward..
Ford Ranger Fog light options 1787699916853-i
looks pretty bright..
cfm56doc
Tampa
2023 Bronco Sas (Hers), 2024 Ranger Raptor (His)
Jet engine field service rep
My understanding is these will not fit flush with the housing, but I am good with that as these will be operating at a much hotter temperature than stockers and the added gap will hopefully keep the cover from deforming from the heat. Time will tell.
Shrek The Raptor
George
atlanta
Okay full assortment of photos
1: high beams, and Baja Designs S1, notice the trees leaning in on either side, the S1s lit those up
Ford Ranger Fog light options IMG_4795
2: just Baja designs S1
Ford Ranger Fog light options IMG_4789
3 low beams and s1s
Ford Ranger Fog light options NO_FUSION_0825_004
4: just low beams
Ford Ranger Fog light options IMG_4792
5. High beams and driving SS5’s with S1s
Ford Ranger Fog light options IMG_4791
6 just ss3 max’s in driving pattern
Ford Ranger Fog light options IMG_4787
8. Ss3 max’s and s1s
Ford Ranger Fog light options IMG_4788
As much as I would love to run the s1 on the road with the low beams, they throw light too tall vertically but they are awesome as filler light on back roads with no other traffic.
Ford Ranger Fog light options IMG_4790
Ford Ranger Fog light options IMG_4794
Ford Ranger Fog light options IMG_4793
Edit to add;
almost forgot the one photo everyone probably wants anyway, just the S1’s by themselves.
Ford Ranger Fog light options IMG_4798
HGHVLTS
Really seems like nothing truly fits flush other than the ones that I have gotten which are a Chinese brand of the stockers, but I do like the idea of a true fog light. I'm looking for something that's a actual "fog light", something that's bright, and something that will not melt my bezels. Definitely liking the concept of the Moustas ones.
scuba mike
Southern Calif
Hvac Job Foreman
ok just finish the other side.. these lights are bright.. but like others have said not for the street.. unless you wanna blind on coming traffic..
WESTRESCUE77
J
Westchester, NY
I just installed the driver side BD light and housing. However, I’m having a tough time getting it level… seems like the housing is a bit crooked. Anyone else run into this?
scuba mike
Southern Calif
Hvac Job Foreman
Level ? the three screw holes on the brackets line up with the mounting holes very good. any pics.. or more info.
Shaft
Washington
Wonder if using the Factory Ember lense will help, should lower brightness alot and match orange DRL if you installed em.
WESTRESCUE77
J
Westchester, NY
Here are a few pics. As you can see, they don't sit centered in the housing and are a little crooked as well. Any ideas for how I can correct this?
Ford Ranger Fog light options IMG_1326
Ford Ranger Fog light options IMG_1327
Ford Ranger Fog light options IMG_1325
Shrek The Raptor
George
atlanta
Can you snap some pics of the back of the mounts also? Mine were originally slightly crooked but I just needed to seat the light better in the rear holder
WESTRESCUE77
J
Westchester, NY
Hmm. Mines pretty well seated in the rear mount so I’m not sure what the issue is….
