Ford performance catch can
rrmarsh
Jose
California
ranger raptor
I installed the ford performance air oil separator kit aka catch cans for a 2025 Ranger raptor with a late year build date and they fit perfectly on the listing it says it won’t fit but it dose incase any one wants to order them
Ford Ranger Ford performance catch can IMG_3042
Ford Ranger Ford performance catch can IMG_3039
Ford Ranger Ford performance catch can IMG_3040
Ford Ranger Ford performance catch can IMG_3038
Ford Ranger Ford performance catch can IMG_3037
RonM_TX
Ron
Conroe Tx
Thanks for the info. I couldn't understand why it would fit as there appears to be no changes.
My 2025 was built a day after the cut off date that Ford listed.😩 Was holding off until the issue was clarified.
rrmarsh
rrmarsh
Jose
California
ranger raptor
Your good to get it if you want it it’s a tight fit on the driver side with a ac line but it shouldn’t hit havnt really put to much miles to confirm that but if it dose hit a 3m foam pad or something like that would be more than enough
Kian
NYC
'26 RR Avalanche Grey
Does MY26 already come with this installed? Or do I need to purchase this..?
It's not installed from the factory. Oems feel the normal vehicle owner won't remember to drain these since some don't remember to check fluids, tire pressure, or even change oil
RonM_TX
Ron
Conroe Tx
How do you drain it. Hard to tell from the pictures.
Wow, that's a lot of work. All the after market I have ever used either had a drain valve or you just unscrewed the bowl
rrmarsh
rrmarsh
Jose
California
ranger raptor
It’s not to much it’s 3 bolts and two hoses
4 more then aftermarket though
RonM_TX
Ron
Conroe Tx
At $700 dollars you would expect drains or a simple
At $690 you would this Ford could have included a drain. How often do they recommend draining?
rrmarsh
rrmarsh
Jose
California
ranger raptor
I got mine for 300 with the code they have and my points for buying the truck so not much more then a aftermarket one and every oil change like every other manufacturer of a catch can
RonM_TX
Ron
Conroe Tx
That price is much more reasonable. I have points from buying the truck, guess that would be a good way to use them. I bought folding rear headrests with some of my points so the catch can will cost me a bit more.
rrmarsh
rrmarsh
Jose
California
ranger raptor
Not required just advise it’s your car at the end of the day it’s up to you what you want to add on or not
