How to empty Ford Performance Catch Cans in a Ranger Raptor?
rocsteady
New Jersey
Federal LEO
I'm not familiar with that system. Mine is so dirt simple, from UPR. Now I'm curious to see the FP setup.
james1108
james
Tennessee
Mines attached to my battery post. Very easy to reach and empty. I’m not sure about the ford performance one.
Aircraft examiner
the j&l kit is hte way to go if you are going to get a catch can. their stuff is so well made and priced way below the other manufacturers
rocsteady
New Jersey
Federal LEO
J&L wasn't available yet when I went with UPR. Had J&L on several previous vehicles.
Depotgeorge
George
Nj
24 ranger
I have the the ford oil separator on the 2.3 just take off all the Allen head bolts out and separate the two half move the top half out of the way and pull the lower half off the mount and empty it. If you want you can disconnect hose but it is not nessassary
Aircraft examiner
That sounds like work. The j+l just requires you to unscrew the bottom. No tools required
Shadow Black Ranger Rapto
St. Louis, MO
Thanks! That may work for one of the cans, but the other is near the firewall closer to the centerline. If I were an NBA center, I might be able to reach it…
sikedsyko
24 RRaptor, 05 Z4
I'd probably remove whichever hose is easiest and use a big syringe with a flexible hose to suck the oil out.
some_guy
some
florida
entrepreneur
I think the OP has the Ford OEM Air/Oil separator shown here in this link.
I have the J&L Oil separator and mine connects to my battery mounting post.
Wow $700 for just a bunch of injection molded plastic and hoses?!
It was way before my time but I remember when engines had a crank case vent to the atmosphere. Now its required to circulate back into the engine and we have to do all kinds of funky crap to mitigate it.
TommyWasabi
Thomas
North Alabama
2026 Ford Ranger Raptor, 2004 Toyota 4Runner 2UZ-FE
EH&S
Agreed, the Ford setup is pricey, but also looks to be a PIA to empty...The J&L that I have is aluminum construction and just unscrews. Not saying its better, but it is simple to empty the can when needed. I haven't even put 1000 miles on my truck yet so once I hit that I'll check the can to see if there is any accumulation.
Aircraft examiner
thats why i like the j&l also. so easy to empty.
on the titan forum, we had a thread to show how much junk came out each time you emptied it. some people would measure each time and some added it to an empty soda bottle and showed the total. on the nissan v8, that soda bottle filled up rather fast. i bet it takes a lot longer on the ranger engines
