Ford Performance LED Headlights
jmt8706
2025 Ranger Lariat
As far as I know for my 2024 Lariat they move when they are calibrating but not when you are moving. The Lariat and Raptor have a dedicated turn signal light that comes on. There is a video of it on here.
Interesting. I assumed they were like the F150 lights that move left and right when the wheel turns.
daytoncarter
Dayton
The headlights do turn with the steering wheel CACTUSGREYFX4's Ranger may be broken, or some setting is off.
What setting do you have to adjust?
Found it in manual I don't know if it's on or off will check tomorrow when I back in truck.
Blue_Raptor
Simi Valley, CA
I am not doubting testimonials here but I just checked and my vehicle settings (sync center screen) and there is no toggle for adaptive lights. My headlights are set to auto so maybe they just do it? I didn’t set the lights to on and then check again though.
daytoncarter
Dayton
Maybe the toggle is for the matrix function, not the swiveling function, but you can read more about the two here: https://www.ranger6g.com/forum/thre...24-crowdsourced-spreadsheet.12611/post-198350
Your headlights should turn with the wheel from stock, but since it's a US built truck, not use the matrix function unless enabled.
So I checked maybe because I am in Canada and not USA I don't have the adaptive lighting function in my settings to turn off or on.
Bonder
Bonder
Manitoba
I am also in Canada and do not have this option (I know the manual shows it as well). I have not found a Forscan setting listed in the spreadsheet that enables it yet.
If someone knows the setting, that would be great.
jmt8706
2025 Ranger Lariat
Around 800 miles on my truck now, and for the first time this morning, they did the calibration movements. 😀
Mine does it 99% of the time, if it doesn't then my high beams don't work so next time I stop I have to restart the truck so the computer reboots.
ShadowDragon24
2025 Ranger XLT Fx4
Heavy Equipment Operator
our trucks are built in the states. Michigan builds all north American rangers. you can enable the matrix"glare free" lighting in forscan. I did on my xlt led reflector lights. didnt work, cuz missing everything for it. but I was able to see the toggle on the screen and stuff.
its not in the asbuilt. its in the easy mode programming one.
I don't have Forscan.
FL_YOTA
2024 (Mk8) Golf GTI, 2016 Toyota Tundra (1794), & 23 Toyota Sienna XSE 25th Ann
Do you happen to know if the glare free/ matrix programing will work on a 2026 Ranger Raptor? I'm in the market for one a d my 2024 Volkswagen GTI has them programmed. It's a huge deal breaker for me to have matrix headlights living out in a more rural area. You won't notice them much in city/ bright areas. But it a game changer on rural/ country roads.
ShadowDragon24
2025 Ranger XLT Fx4
On my 25 XLT, in the non as built programming. I was able to get the options to come up for glare free, and matrix. But I have the level 2 led reflector headlights, and not level 3 led projector headlights. So I couldnt activate them. So unless they changed a lot of software options, I can not see why you cant enable them.
