Forscan ASS disabled
Dondaddy-Maine
Don
Maine
2025 Lariat FX4
Manager
I get a "Charging System" code on my 2025 Ranger Lariat after disabling Auto Start/Stop (ASS) with FORScan. Any idea for a fix, the code will not clear using Forscan.
av8r
NY
I don't believe anyone has figured out how to disable ass on the NA rangers using forscan without causing errors to appear.
stuartmunto
Stuart
Perth, Western Australia
2023 Ford Ranger Raptor
You can not disable the start/stop via forscan! Here's hoping you backed up before making changes
Make sure you follow the forscan spreadsheet in the main official forscan thread - you can do some serious damage if you make changes randomly
Lake Ontario
ā€œA little knowledge is a dangerous thingā€
bdallas9
Washington
sales
All is true here. S/S can’t be disabled on us trucks. The warning light can be removed via Forscan but the rest not so much. Only way I’ve be able to do it is with a third party bypass module.
Now the charging system error or notice could be something else. I was getting those every once in a while and came out one day to a dead battery. It turned out to be a faulty battery. Dealer replaced under warranty. I’d get that checked.
PatrickKnight
Patrick
Indy
Service Advisor
Not true. I disabled auto start stop on my 2022 Maverick using forescan and it worked perfectly. It just takes someone testing it out and ruining their truck for my benefit😬
ryanO
Ryan
2025 RangerXLT
Sales
🤣🤣.....dude, if you didn't back up your original programming you better break out the checkbook.
People messing around with Forescan is insane.
fordgt
Your 22 Maverick isn’t a 24+ Ranger though, is it? I think you could do it on 5 G Rangers, haven’t seen any reports of it working on a 6Gen.
ShadowDragon24
2025 Ranger XLT Fx4
Heavy Equipment Operator
just go on www.motorcraftservice.com and enter your vin, to download the factory asbuilt data the truck rolled off the line with.
PatrickKnight
Patrick
Indy
Service Advisor
Yep, I get it.
Different names on the tailgate and they must different. Turns out, manufacturers normally use the same base line code to make there vehicles. The pro rust engineers at Ford can't be that different to everyone else out there.
If they don't use the same throughout the line up, explains their recall record last year. For our sake, let's hope they do.
