radial
Rich
Maryland
This post from user moproblems shows all the modules and the values you need to change using FORScan to turn on the glare-free headlights feature. Just be sure to backup each module beforehand. This one involves changing a lot of values in a number of modules, so you want to make sure you can recover from any data entry errors. Good luck, and let us know if you run into any problems.
https://www.ranger6g.com/forum/thre...sourced-spreadsheet.12611/page-17#post-226557
Oh, and if you want to work from the master spreadsheet, all the necessary info is in the Features-Confirmed tab, lines 44 through 51.
ColeTrainsRR
Cole
Minnesota
E-Tec 3
2025 Ranger Raptor. Not overly familiar with forscan as i'd only used it on my '22 Bronco Badlands a few times. but when i go into the modules they don't show lines and numbers/letters. When i want to disable double honk or have fogs stay on with high beams all i get is enable/disable in categories related. I changed the double honk to disabled(opposite of what it says AS BUILT) and write it and is comes with an error around 65% of writing that it was disconnected or disrupted but i did nothing but hit WRITE. Is there a change with the newest version of ForScan or is it the '25s that are locked out yet?i bought the extended license and can't do anything to the truck it would appear.
Texas Ranger
Austin
I got it all taken care of and I will give it a test tonight, thanks for the help friend.
DIYPSCM
SF Bay area
2024 Ranger 2.7 Lariat
What about non-Raptor models?
radial
Rich
Maryland
I have only tested this on the 2024 Raptor that I own, so I can't speak from personal experience as to whether it works on other models. But I don't see any reason why it wouldn't also work for your 2024 Lariat. Check the instructions in the spreadsheet which document the only Lariat-specific differences.
RangerPA
York County, PA
2025 Ranger XLT FX4
full post above. Use at your own peril.
I have a 2025 XLT and this didn't take away the nag screen where you need to press OK. I prefer not to 0000 out all of the entries like the spreadsheet suggests. Anyone manage to get the nag screen off in the US on a XLT?
Maybe
Brock
CA
23 Bronco, 24 Mustang GT
Can someone give me an exact breakdown of what i need to use forscan?
device, software, etc. Thanks
RangerPA
York County, PA
2025 Ranger XLT FX4
I did my father in laws 2025 xlt using the spreadsheet. It worked in his.
RangerPA
York County, PA
2025 Ranger XLT FX4
The spreadsheet specifically mentions " unclear if this affects airbags " if you 0000 everything out. Maybe you aren't worried about potentially disabling airbags, but I have kids in the car often.
Ok, good for you. You mentioned nothing about airbags or anything about why you are scared to put the zeros in there. I just said it worked on my father in laws xlt because you said it didnt work for you. It also worked on my xl.
RangerPA
York County, PA
2025 Ranger XLT FX4
LOL, I quoted the guys config that worked on his Raptor. I mentioned it didn't take away the nag screen on an XLT and I said "I prefer not to 0000 out all of the entries like the spreadsheet suggests". Did you not see that part?
Yup, just commented that it worked for our trucks
I beleive my comments appear rude so i wish to apologize for that. I meant no disrespect, the point of everything is to just say that combination works on my 24 xl and my fil's 25 xlt. Sorry
RangerPA
York County, PA
2025 Ranger XLT FX4
Thanks man, all good. Have a great weekend!
