DiogoPaganini
Diogo
Brazil
Ranger XLT 2024
Actually now I remember, TTA will not work if you have hard switch input for HDC.
You have to add D6 which means you will no longer have hill decent control working from the switch panel but you can still activate it from the off road screen.
Does that make sense?
I'll test this tomorrow. I saw in some comments on Facebook that maybe it should be F6 to maintain hill decent control. What do you think?
Raptortugal
Portugal
Ranger Raptor 6g
I don't hear anything. Could it be a noise like when I change from 2H to 4A?
When TTA is activated and you turn the steering wheel, there is a very surprising (scary) noise when you start driving.
Ragner
Victoria
2022 ranger XLT
Supervisor
I've maintained HDC but only via the soft button on the off road screen. I've tried lots of combinations to get it in conjunction with the HDC hard switch but nothing has worked.
I've tried both F6 and D6 and D6 was the better option if I recall.
DiogoPaganini
Diogo
Brazil
Ranger XLT 2024
I tried again today without changing the programming, and it simply worked. It seems the truck just needed a night's rest. The HDC hard switch is still working normally. Original 760-03-01 was 683C 5463, changed to 683C D493.
mAtTyG04
Matthew Glazier
Edmonton
2025 Raptor Ranger
Trail Turn Assist
Just revisiting the Trail Turn Assist functionality in light of the updated module data pages in the spreadsheet - thanks for the heads up @Waffel
If the new ABS 760 (Ranger Specific) worksheet is correct for the Ranger Raptor then the change to be made in the as-built ABS module to get TTA working (for my Ranger in any case) would be as follows:
Existing:
760-03-01 F27C 764F (Which translates to: TTA Without TTA • AVH With AVH • TBC With TrailerBrakeController • TCS Trail Control Switch input from the APIM • SDMG SDM Gen4 • HDCST HDC Soft Switch Input from the APIM)
Should be changed to:
760-03-01 F27C F64F (Which translates to: TTA With TTA • AVH With AVH • TBC With TrailerBrakeController • TCS Trail Control Switch input from the APIM • SDMG SDM Gen4 • HDCST HDC Soft Switch Input from the APIM)
I shall try this the next time I get out onto the dirt.
Tried this but my 760-03-01 looks nothing like this. I did get the button to show up with the APIM changes. Ideas?
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet IMG_0900
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet IMG_0899
CrustyNoodle
Peter
Melbourne, Australia
Mechanical Engineer
That is rather odd! My ABS 760-03-01 only has 8 hex digits but yours has the full 12. Also, your Forscan image shows that you don't have the "Write" button next to the 760-03-01 item - I'm pretty sure mine did.
Is it possible that your car is newer (mine has a late 2022 build date) or uses a different ABS module?
Anyone else care to speculate?
mAtTyG04
Matthew Glazier
Edmonton
2025 Raptor Ranger
2025. I can write.
CrustyNoodle
Peter
Mechanical Engineer
2025. I can write.
OK, then we can try decoding your string to see if it makes sense and go from there... Unfortunately the spreadsheet only has information for the first 6 digits but comparing yours to mine this is what I get:
CNmAtTyG04
Before TTA760-03-01 F27C 764F760-03-01 9B42 C14C FF54
Set 1 Digits
760-03-01 **xx xxxx
F29B
Set 1 DecodedACC Adaptive Cruise Control Stop & Go • CMB With CMbB Always • HDC Trail Control [MFAL FECAD] • TBA Without TBA MFAL DAXAA (LESS ASSIST PACKAGES) • PA With FAPA [MFAL HNSAC(FAPA)]ACC Adaptive Cruise Control • CMB Without CMbB N/A • HDC Trail Control w/ Trail 1 Pedal [MFAL FECAE] • TBA Without TBA MFAL DAXAA (LESS ASSIST PACKAGES) • PA Not Used
Set 2 Digits
760-03-01 xx*x xxxx
74
Set 2 DecodedRBA RBA • S With eShifter • AFS With AFS [MFAL GPAAW]RBA RBA • S Without eShifter • AFS Without AFS [MFAL GPAAW]
Set 3 Digits
760-03-01 xxx* xxxx
C2
Set 3 DecodedPIB With PIB [MFAL HKLAB,HKLAE,HKLAF] • AH With AutoHitch [MFAL C2FAB(AutoHitch)] • PATS Enable • ADD ADD collection EnabledPIB Without PIB [MFAL HKLAA] • AH Without AutoHitch • PATS Disable • ADD ADD collection Enabled
Set 4 Digits
760-03-01 xxxx **xx
76C1
Set 4 DecodedTTA Without TTA • AVH With AVH • TBC With TrailerBrakeController • TCS Trail Control Switch input from the APIM • SDMG SDM Gen4 • HDCST HDC Soft Switch Input from the APIMTTA With TTA • AVH With AVH • TBC Without TrailerBrakeController • TCS Trail Control Switch input from the IPC • SDMG SDM Gen3 • HDCST HDC Hard Switch Input from the ATCM
Set 5 Digits
760-03-01 xxxx xx**
4F4C
No info for the last two digits
760-03-01 xxxx xx**
I'm not sure how that translates into what you actually have on your car but mine (CN column) describes my features correctly.
Also note that you have the value "C1" in the 5th and 6th digit which according to the worksheet means that you already have TTA enabled?
To enable TTA on my vehicle, I changed the 76 in xxxx **xx to F6 to enable TTA.
None of this solves your problem though I'm afraid.
mAtTyG04
Matthew Glazier
Edmonton
2025 Raptor Ranger
CNmAtTyG04
Set 1 Digits
760-03-01 **xx xxxx
F29B
Set 2 Digits
760-03-01 xx*x xxxx
74
Set 3 Digits
760-03-01 xxx* xxxx
C2
Set 4 Digits
760-03-01 xxxx **xx
76C1
Set 5 Digits
760-03-01 xxxx xx**
4F4C
760-03-01 xxxx xx**
Weird. Truck didn't come with TTA. I did the first 2 APIM changes first and that added the TTA button on the off road screen (buttons there but does nothing). Would it be possible that the changes the APIM's changed my ABS 760-03-01? I wouldn't think so but your right. According to my stock ABS 760-03-01 having "C1" it looks like it indicates that it's equipped with TTA.
CrustyNoodle
Peter
Mechanical Engineer
There used to be an alternate ABS module sheet in the workbook - I think it was for the F150 though. Not sure if the codes described in that would make more sense for you. It does seem particularly odd!
mAtTyG04
Matthew Glazier
Edmonton
2025 Raptor Ranger
2023 F150:
I might try changing my 2 to a 3 in the last digit of box one
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet 1746539169881-w
CrustyNoodle
Peter
Mechanical Engineer
It's a long shot... Please report back here if it is successful though - it would be good if others can benefit.
mAtTyG04
Matthew Glazier
Edmonton
2025 Raptor Ranger
Just tried it along with many other combos. Nothing but brake failure messages.
