G.O.A.T Offroad X Carbon Shock 3.0 Replacement Coilover Package
nedmo
Gold Sponsor
Ned
Australia
2022 Ranger Raptor
Ned from G.O.A.T Offroad here!
Last week we fitted Australia’s first full shock replacement package for the Next-Gen Ranger Raptor — designed right here by us, built by @carbon_shocks in the US.
Here’s the big deal: the factory Raptor “2.5s” might look decent from the outside, but because of their internal bypass design, the actual piston is much smaller than a true 2.5. So jumping to these 3.0-inch Carbons isn’t just a mild upgrade — it’s a huge leap in oil capacity, cooling, and damping control. The difference in composure and performance is unreal.
They run 12-inch remote reservoirs with high and low-speed compression adjusters, adjustable preload to dial in your exact ride height, and the best part — we use Eibach springs that can be tailored in 50 lb/in increments to match whatever load you carry. Daily driver, touring rig, or full send — it’s built for you.
And yes, we’ve developed a plug-in module that keeps all the Raptor drive modes working, even without the live valves. Fully bolt-in, no compromise, no dash lights
This is just a sneak peek — proper testing and tuning still to come.
G.O.A.T Offroad x Carbon Shocks
Performance without limits. 🐐💥
Ford Ranger G.O.A.T Offroad X Carbon Shock 3.0 Replacement Coilover Package 0a52adc0-f3fb-4d70-9785-5ba94ef086f2
Ford Ranger G.O.A.T Offroad X Carbon Shock 3.0 Replacement Coilover Package 1aa15ed3-7867-49df-acde-60fabdae6634
Ford Ranger G.O.A.T Offroad X Carbon Shock 3.0 Replacement Coilover Package 0197dbc0-3cfd-49dc-98ee-9d5c5ee81f91
Ford Ranger G.O.A.T Offroad X Carbon Shock 3.0 Replacement Coilover Package ab4bc8f9-e1e1-487f-a5e2-6969da5d102f
Ford Ranger G.O.A.T Offroad X Carbon Shock 3.0 Replacement Coilover Package 714565df-fe08-40c0-868d-14e5bcec5f78
Ford Ranger G.O.A.T Offroad X Carbon Shock 3.0 Replacement Coilover Package 3b5dffcb-18ec-4ace-9364-15e0bb140b2
Ford Ranger G.O.A.T Offroad X Carbon Shock 3.0 Replacement Coilover Package c7320292-0c5a-49da-9cf2-a5b03f896dd1
embedded rock
Earth
One truck, two motorcycles
Curious about the module. Does it replicate an OEM live valve shock and the truck keeps making shock adjustments that just don't result in anything? Suspecting that keeps the RR out of lights and fault codes.
nedmo
nedmo
Gold Sponsor
Ned
Australia
2022 Ranger Raptor
Yes and it also has other benefits. If any of the sensors left on the vehicle were damaged, it would prevent the car from going into any error modes too.
Locust13CT
Tom
CT
Aircraft Inspector
Do these sit at factory ride height? or end up lifting the truck? Upper control arm upgrades required? Any other supporting mods suggested?
nedmo
nedmo
Gold Sponsor
Ned
Australia
2022 Ranger Raptor
So our goal was to maximise droop and move the travel zone down, to allow for clearance at full compression for larger tyres. This means that if you run less than 2in of lift, you will be closer to bump stop at ride height, which will make the ride not as plush as running 2-3in of lift.
Due to the longer extended length, you will need all of our supporting mods. UCA, clevis steering kit and a diff drop.
Havasu RR
Craig
Lake Havasu, AZ.
Entrepreneur
What is the diff drop?
embedded rock
Earth
I don't see the diff drop parts on the goat website
Should be some simple blocks, but maybe a diff drop hasn't happened yet.
There's a lot going on when there's talk of up/down travel, bump stops, springs and spring rates, CV angles, spring preload, hi/lo speed compression adjustment, rebound dampening adjustment, and not yet mentioned are long-arms etc. There are details we should know of our RR suspension before jumping on upgrades like what is the OEM f/r shock travel, what are the OEM spring rates, what does a 50lb spring rate increase do for lift on OEM suspension, etc. Without these details, how does one select aftermarket suspension parts to achieve what the RR owner is after? I see this in the m/c world too and not a fan of someone else telling me what I want/need for suspension performance.
Anyway, diff drop parts as seen for the Tacoma are not much in cost, but anyone who lowers the front diff ought to have a well thought-out plan of where they want to go with suspension performance.
Havasu RR
Craig
Lake Havasu, AZ.
Entrepreneur
Currently running goat off-road strut spacers.
2 in in the front and 1 in the rear. I added foutz Motorsports hydraulic bump stops in the front with limit straps. Has been working really well. I do a lot of off-roading and have been driving the truck hard. Airborne with full droop and full compression on landing. So far working really good. If you want to get any more serious, you're going to need to put a bypass shock next to the coilover or do something like being discussed here. I really like the plush ride though at low speeds with the live valve shocks.
Havasu RR
Craig
Lake Havasu, AZ.
Entrepreneur
Ford Ranger G.O.A.T Offroad X Carbon Shock 3.0 Replacement Coilover Package PXL_20251012_154748168
