Hood won't close!
NYRangers
Randy
Catskills NY
2013 Raptor, 2021 RS6, 2018 GT3
Trade
Anybody have a problem with their front hood not closing completely? Mine catches the first latch but not the second. Any quick suggestions on how to remediate?
v8 goat
North Texas
I’m not sure - the latch may need to be adjusted. I will say that I had a difficult time closing mine (only been open once). I had to slam it a little harder than expected, but it did latch. I haven’t had it open since.
NYRangers
Randy
Catskills NY
Trade
I tried slamming pretty hard, to the point I was comfortable with, but still no secondary latch. Same problem with the doors. Pretty brutal quality control at Ford.
51T
Same. I only had mine open once but it was hard to get closed again. Had to drop it from a uncomfortable height. I do notice that the panel gap along the passenger side is much wider than on the driver side.
08mojo
North GA
Every car I've had in the past 5 year or so has been this way. Not sure why the change, but it's been noticeable.
Typically, if you open the hood 2ish feet and drop it, it should close.
Ford Motor Company
Official Ford Account
Ford
Dearborn, MI
Ford Ranger
Hi there! I can look into your Ranger's concern on my end. To get started, could you please send a private message over with the name/location of your local Ford dealer and your Ranger's VIN?
AlpineClimbing
Washington
Ranger
I test drove a 2024 Ranger last week - I couldn't close the hood after popping it and neither could any of the dealership staff. Seems like a quality control issue.
James D
James
Sugar Land, TX
2025 Ranger Lariat, 2022 Jeep Compass
I test drove a 2024 Ranger last week - I couldn't close the hood after popping it and neither could any of the dealership staff. Seems like a Ford quality control issue.
I had trouble with the hood the first time too. Turns out the hood prop rod wasn't stowed away properly. Haven't had trouble since.
GigaRaptor
Sean
West Michigan
2024 Ford Ranger Raptor, 2020 Ford Explorer ST
This wasn't the first post I had planned...
But I am glad to hear I am not the only one. I got home from the dealership, and I was checking things out and decided to open the hood and take a look. Went to close it and I dropped it from a foot or so and it didn't close. Dropped from a bit higher and still no go. Decided to try and push down on it with my forearms and now I have a nice little quarter-sized dimple on the hood my brand new Raptor. :/
NYRangers
Randy
Catskills NY
Trade
Well I just sorted mine out and indeed it involves dropping from an obscene, and should be unnecessary height. Just cross your fingers and hope it doesn't blow all of the windows out in the process.:whew: As for the doors, same thing...just go out it the way Matt Rempe goes in for a bodycheck, but don't miss.
NASSTY
ME
I adjusted my latch and my hood closes easy now.
I already had the plastic cover off the radiator support because I was installing the Raptor style grill lights so the latch was right there in the open. I moved the latch up about 3/16" and all is good now.
davidf
Old Saybrook, CT
2024 Ranger Lariat on order
I too tried everything and finally the dealer created a service ticket. They took part of front grill off to raise the whole closing latch. Works fine now. Clearly a quality control issue.
PawnX
PNW
Ranger
I wonder if this has to do with the original hoods having issue's and them having to change the manufacturing process on them.
Perhaps yours had the original hood and the replacements are just different enough to require some further adjustments on the latch side.
Looks like it's petty common looking at the responses.
I can see this being rushed as they replaced 1000's of hoods.
