How to clean area between tailgate and bed?
RaptorBaby23
24 RR
Hi. What is the best way to really deep clean the gap area between tailgate and bed? High pressure is probably not recommended I can’t find any posts on this.
thanks!
Bruce
Bruce
Minnesota
I have solved that problem by installing a soft rubber tube that is used as insulation on water pipes. I cut it to length and then gently push it in the space between the cab and box. I remove it when I wash the vehicle. Make sure you get the softest material and not the harder pipe insulation.
I got tired of using a long nozzle on a shop vac to suck up the leaves and pine needles that fell in there. Been using this way of sealing the space since my first Ranger in 2019.
Trimjb
Tennessee
2024 Ranger FX4
thanks!
Are you talking about when the tailgate is folded down?
Not between the cab and bed?
Photo would be nice if possible.
Bruce
Bruce
Minnesota
No I am not.
Sorry, I miss read the original post.
Since 2019's Ranger the area between the cab and bed has been a problem keeping clear of dirt and leaves. Just thought that others are having the same issue.
For the original post -- you can remove the tailgate to clean. I have removed the tailgate several times -- although it was easier with the 2019 as it didn't have the cylinder to slow the opening.
PA RangerRick
New Oxford, PA
'26 Ford Ranger XLT FX4, '24 Kia EV6, '20 Mazda MX5, '19 Husqvarna Vitpilen 701
Very clever. Can you share a photo or two? Very curious how that comes together… TY
Ranger Glen
Glen
Maryland
2020 Ranger XLT
I pressure wash it and my whole truck. Foam cannon and pressure wash.
OmahaBaseball
Nebraska
2025 Ford Ranger Lariat 2.7L
Legal - Contracts
Here you go. Found this soft foam rubber pipe insulator at Menards. (big box store in the midwest)
Good idea -- I will need to see about doing this!
got3fords
James
Central Va.
The OP was talking about the gap between the tailgate and bed.
NOT_RAPTOR
Cleveland
The thought that debris/rocks would get in between the crevices of this and grind against my paint would stop me from ever doing this. Looks like a small pebble or stone trap to me.
Bruce
Bruce
Minnesota
Well, since I live where there are trees with leaves, fall brings a challenge to keep them out of the space, not to mention the spring when tree seeds fall.
You must live were stones and pebble come from above as I have never had a problem. Yes, it does get removed when the vehicle is washed. The rubber gets a shopvac vacuum also before being reinstalled.
OxygenMask
Phil
Eugene, Oregon
2025 Ranger Raptor, 2012 F350
thanks!
I've never had much problem cleaning there on any truck, and the Ranger is easier than most with it's huge gap...
I use a separate mitt for wheels that never touches my paint, I use that for places like just inside the fenderwell lip and the gap between the tailgate and bed. (I also don't get too picky about that area, it will always be dirty anyway...)
NOT_RAPTOR
Cleveland
So you're saying there's a height limit to how high a vehicle in front of you can fling a rock into the air, interesting theory.
I'll have to go back to the drawing board on how I got paint chips on my roof, I thought I had it figured out.
alrashid2
PA
I'm confused. You said between the Tailgate and the Bed? Do you mean between the cab and bed?
