Intercooler experience
cleffe
Cgrus
24 Ford Ranger Raptor
I've found a lot of threads summarizing which aftermarket ICs are available, but not much regarding people's actual experience with them. Can someone who has installed and spent some time driving with an aftermarket IC post their experience? Do you notice any benefit after a few hard pulls compared to the stock IC, or is there not much noticeable difference?
@Goosetuned just went over intercoolers in a post he did. search under his name and it should pop up
Tallonh
Tallon
oklahoma
2024 Ranger XLT FX4 2.7L
put the cvfab intercooler and charge pipes in mine from the bronco kit. Had to remove the lower shutter took about 3hrs to install. Got some of my mileage back after I did the level, bigger and heavier tires. As for hard pulls and such without tuning idk how much of a difference it would make but I was mainly chasing mpg's anyway. Id say pending what gear the trans is searching for (the tuning on these is mediocre at best) feels like maybe a little more boost lag from no throttle. Also im in the 2.7L v6 that things pretty quick anyway.
CrushTon207
Maine
2025 Ranger Raptor, 2015 Jeep Grand Cherokee, 2022 Ford F350
I installed the Cobb last week. I am going to make a more detailed post at some point but here are a few initial observations.
With the Cobb in general driving Air Charge Temps (ACT) are around 10F higher than Intake AIr Temps (IAT) whereas with the stock intercooler I was generally seeing a 20F difference. I have yet to be able to see 130F ACT in any situation with the Cobb whereas I could get to 130F with the stock intercooler with two hard pulls in a row.
Its still spring where I live and ambient temps have been pretty low, 40F to 70F, so I haven't seen how it will perform as ambient temperatures get up to what I would call hot. I do have concerns about low speed cooling as temperatures rise.
The Cobb intercooler does not utilize the rear shutter assembly. If you haven't looked at how that works you should. The rear shutter assembly includes a seal that seals the rear of the intercooler to the fans and allows the fans to suck air through the intercooler. I would imagine this would help cool things down at low speeds in high ambient temps.
The Cobb intercooler does seem to cool down acceptably quick after it does warm up even at 20 to 30 mph which is something I was concerned about. It should be noted that I was surprised at how little the ranger actually gets into boost under normal driving conditions which should help keep things cooler with either intercooler, although I was also surprised at how much vacuum this truck makes when off throttle. My theory is that under vacuum no air is passing through the intake so IATs and therefore ACts will rise from engine bay heat until you get back on the throttle a little bit and start to draw fresh air through the system.
I will continue to observe as things get warmer here and report back if I see issues.
Please not that all of the info I have provided is anecdotal and I have not done any structured testing.
MeBEEF
Peter
Gold River, CA
So it is performing WORSE than the stock? Did I read you right? In any driving situation I'd expect it to perform better, this is interesting. If the intercooler is bigger it could be soaking in engine bay heat. I think the stock intercooler has some sort of a plastic frame around it? perhaps this is it. But yeah when you're on the throttle this would go away.
Maybe evaluate your Cobb and see if you can add some insulation of some kind around it. I am sure something like home depot R7 insulation would work, thin.
Very interesting thanks for sharing. I am interested in an AIC as well but not sure if the juice is worth the squeeze.
CrushTon207
Maine
The Cobb intercooler is cooling the air more than stock so far by my non scientific observations. The stock intercooler ACTs were generally 20F higher than IATs. The Cobb intercooler ACTs are generally 10F higher than IATS.
IATs are the temperature of the air near the intake. Generally just before or after the filter. ACTs are the temperature of the charged air post turbo and intercooler.
I used that delta of temperatures as my measure because ACTs vary so much depending on so many factors that it's hard to gather meaningful data from ACTs alone.
I can't speak to the efficiency or flow at all as I don't have any way to measure that.
Blue_Raptor
Simi Valley, CA
He did provide info, but I think there is still more beneficial info that can be provided by other users, and this was something I had posted about previously. Personally I feel the most useful bit
For this reason, I think a better measure is seeing what the charge temps are related to ambient temp. How close to ambient temps is the IC keeping the charge air? Because ambient is your floor (or ceiling depending on how you look at it).
Also, I still dont know how much effect the active shutters have on charge air temps. I got my RR in January, and with ambient temps in the 40s-50s my charge air temp would be in the 80s-90s on the freeway just on cruise control (meaning engine fully warmed up and IC not heat soaked).
So, do any of the aftermarket IC's keep the charge temps close to ambient while still retaining the active shutters?
As an example, my previous car was a Fiesta ST with a CPe IC and a Cobb accessport (with a tune) which I used for the gauges. That IC kept the charge temp within 10 deg of ambient, but of course that car does not have active shutters.
So for me, if an aftermarket IC keeps the charge temps fairly close to ambient its worth looking at. And our trucks have all the gauges to monitor this from stock (doesnt require an accessport to see charge temp).
CrushTon207
Maine
I respectfully have to disagree. While it is all of course related to ambient temperatures I have noticed that, like most turbo engines, the RR creates a ton of heat under the hood.
From my experience so far, the IATs on this truck are routinely 10 to 30 degrees over ambient in everyday driving. Not stop and go but varied speed in town/rural driving. I don't think you can expect any stock location intercooler to get charge temps below IATs without meth or water.
For me keeping an eye on the difference between IATs and ACTs are a good measure of intercooler efficacy.
I have my gauges set up like the following picture to monitor things real time:
Ford Ranger Intercooler experience 20250521_120618
It's pretty interesting to watch the relationship between IATS and vacuum/boost and then the relationship between ACTs and IATs. I really wish I could monitor the shutter position as well. I may consider hooking up my FCCAR to see if it shows intercooler shutter position.
Blue_Raptor
Simi Valley, CA
Sure, but (almost) no matter how hot underhood temps are, compressing the air makes the intake air much hotter, and it is ambient air that is cooling the IC.
Another example from my Fiesta: the Fiesta had an air temp sensor after the turbo but before the IC. And the gauges on the Accessport are a real time "max" reading feature so each gauge you have configured shows the real time and the highest. Typical post turbo air temps after pushing a bit of full boost were 320-370-ish. Then post IC temps would still be within about 10 deg of ambient.
So, I'd still say the much more important stick to measure an IC's effectiveness is how close the IC gets charge air to ambient temps.
Blue_Raptor
Simi Valley, CA
I have my gauges close yours.
Ford Ranger Intercooler experience IMG_9265
Ford Ranger Intercooler experience IMG_9266
CrushTon207
Maine
You have a valid point. When thinking about temperature differentials like that I suppose worrying about 10 degrees here or there don't really matter either way. Knowing how hot it is under the hood of these trucks I would imagine that sensor placement and charge pipe routing probably plays a big role in the temperature readings of all sensors. With that in mind its probably hard to compare to the Fiesta as well.
Blue_Raptor
Simi Valley, CA
Yeah, even though Ford put a good amount of underhood ventilation on the RR's, I've recently thought about trimming the pad on the underside of the hood strategically underneath the hood vents and/or possibly trimming the underside of the vents themselves to allow more heat excavation.
CrushTon207
Maine
We finally had some truly hot weather yesterday and I actually got a chance to go on the highway as well. It was 92F with very high humidty.
Cobb intercooler kept ACTs within 8 to 12F of ambient on cruise at 80mph.
Multiple full throttle pulls never pushed the ACTs past 120F which is definitely an improvement on the stock intercooler. I could hit 130F with the stocker quite easily at 60 degrees ambient.
I am really starting to question the operation of the shutters though. At low speeds with a lot of off throttle situations my ACTs were approaching 130F often. As soon as you hit the throttle they drop quickly. I parked the truck and got out and looked at the shutters and they were closed while the fans were running and ACTs were at 132F.
I am going to remove the shutters tomorrow and see what happens then. It also gets very cold here so I do want to remove them in a way that I can easily put them back on in the winter. Ill keep you guys posted on the results.
Blue_Raptor
Simi Valley, CA
Excellent info right there, thank you.
It would be nice if there was some info out there on exactly when the shutters open and close. What situations cause what. And while I do care some about mpg a bit (we certainly didn’t buy these trucks for mpg though) it’s likely that the shutters on just the IC area will not effect mpg very much nor cold start warm up. But I appreciate you offering to be the guinea pig ?
CrushTon207
Maine
I agree that it would be really interesting to see the parameters for shutter opening and closing. I was stunned to see them closed in park when ACTs were at 130F.
I hypothesize that they are closed anytime you aren't on the throttle judging by how quickly the ACTs come up going down hills or basically any time spent off throttle.
In lieu of a datalog showing shutter position if someone had two go pros and was talented in video editing I would love to see a video of the dash and a video of the shutters from outside the truck synchronized. I don't have the time or equipment for that. I still might try to hook up my big FCAR scanner tomorrow to see if I can find shutter position anywhere in the data.
One thing to note, from what I have gleaned from some of the F150 Raptor forums. Supposedly the shutter system was implemented after some vehicles were ingesting water and misfiring as a result of condensation in the intercooler and not just for mpg and emission purposes. I don't know if there is any truth to that but that is the reason I want to be able to reinstall the shutters in the winter.
