Introducing JXB PERFORMANCE center driveshaft billet carrier and improved bearing kit (FRD12A0-BRG- S) for 2024+ Ford Ranger/Raptor
ATestBishop
Walnut Creek, CA
2024 Ford Ranger XL
Got excited to share an unboxing/first impressions post to share this kit for 2024+ Ford Ranger or Ranger Raptor.
Center driveshaft billet carrier and improved bearing kit shown in photos.
First impressions are.... Top Quality, Quality packaging, Quality Materials, Quality design.
In hand, screams precision and strength. Just feels like it is made to exact tolerance and details.
Here is the link to the product and configurator- https://www.jxbperformance.com/prod...019-driveshaft-center-support-bearing-upgrade
Will be sharing the install as well soon.
I need to mention, I met the owner of the Company Jay and he is all about sharing his Automotive passion with everyone, it's actually inspiring to learn from him and I had heard of the FANcar previously and knew some history behind various past concepts/applications but learning about his involvement with it and his future plans...his Automotive passion and talent is inspiring.
Ford Ranger Introducing JXB PERFORMANCE center driveshaft billet carrier and improved bearing kit (FRD12A0-BRG- S) for 2024+ Ford Ranger/Raptor PXL_20260518_221838899.MP
Ford Ranger Introducing JXB PERFORMANCE center driveshaft billet carrier and improved bearing kit (FRD12A0-BRG- S) for 2024+ Ford Ranger/Raptor PXL_20260518_222220114.MP
Ford Ranger Introducing JXB PERFORMANCE center driveshaft billet carrier and improved bearing kit (FRD12A0-BRG- S) for 2024+ Ford Ranger/Raptor PXL_20260518_222526616
Ford Ranger Introducing JXB PERFORMANCE center driveshaft billet carrier and improved bearing kit (FRD12A0-BRG- S) for 2024+ Ford Ranger/Raptor PXL_20260518_222248369.MP
Ford Ranger Introducing JXB PERFORMANCE center driveshaft billet carrier and improved bearing kit (FRD12A0-BRG- S) for 2024+ Ford Ranger/Raptor PXL_20260518_222545812.MP
Fred
Manitoba, Canada
Seems like a solution in search of a problem.
ATestBishop
Walnut Creek, CA
2024 Ford Ranger XL
Couldn't say anything about possible performance or longevity advantages yet as I haven't installed it yet, but theoretically if the factory rubber decayed faster than the bearing this at least allows replacement of the rubber seperate of the bearing, and in my case it was at the least motivation to dismount the shafts to paint them and get rid of the rust look...
saxdogg
Jeremy
D/FW
2026 Ford Ranger XLT FX4
Looks nice, but is the center carrier a known weak point? What's the advantage of upgrading to this from a stocker?
ATestBishop
Walnut Creek, CA
2024 Ford Ranger XL
There were apparently issues on some 5G Rangers from what I read, one advantage is since it's a two piece design the rubber cradle for the bearing is replaceable and there are 2 different options for the rubber. The bracket is substantially more robust as well which may be an advantage. I'm still installing now and will update when completed.
josephp732
Joe
NJ & FL
Thanks for posting, this is very cool for a lifted truck as it will help with less drive shaft ubolt stress/wear because it creates a "softer" slope angle from the transmission to the rear diff.
ATestBishop
Walnut Creek, CA
2024 Ford Ranger XL
Certainly, there's a custom spacer kit as well to get that position adjusted. So I'm just waiting on a 26mm hex socket and bearing puller to install, already made good progress so far
is this the set the dudes on facebutt wer showing a couple months ago? those look great and i can totally see the benefit of it after having bmws where the center support goes out enough that i basically did it each time i did a clutch. the rubber tears around the bearing and i had to drop the two piece driveshaft and make an alignment mark on each piece so they stayed balanced when put back together again.
that bearing support rubber looks like it will last waaayyyy longer than my stock bmw ones did. i think these would wear out so fast because of the cars being autocross cars
thats awesome. i was so close to being part of that original buy.
ATestBishop
Walnut Creek, CA
2024 Ford Ranger XL
Will update when install is complete, waiting on a couple needed tools to finish
