Looking for bed floormat
fordc51
Jim
Cumming, Ga
93 f150, 2025 ranger xl
Im Looking for suggestions , upside, any downsides to specific bedmats for a 25 ranger xl. Planning to checkout amazon first. Ill probably go with a spray-in
bediner later. Use mat so things dont slide. As far as hauling ,use mainly for Home depot runs, etc
Maybe a little firewood occasionally..Likely get a small trailer also.
the tripleAliners works great. i just did a write up on it compared to another brand i had in my truck.
OxygenMask
Phil
Eugene, Oregon
2025 Ranger Raptor, 2012 F350
I've had plastic bedliners in past trucks. Things slid around, over time they warped, debris got underneath, and when I removed one after 12-13 years it had chafed the paint and there was rust starting. I'll never do one again.
I've had spray in, it's so low maintenance and durable (if done right with proper prep) but does little to prevent denting up the bed and is hard on the knees. It's a bit abrasive to haul stuff so I keep packing blankets handy. For a truck doing truck stuff this is my choice. Not DIY, but pro sprayed, it's worth it.
For my RR I went with a rubber bed mat. They start at $50ish on Amazon but I decided on the Ford mat. Nice mat, perfect fit. I think it will fit my needs well, this ain't no work truck.
My F350 , 14 years of being a work truck:
Ford Ranger Looking for bed floormat IMG_20260227_110338528
Ford Ranger Looking for bed floormat IMG_20260227_110348737
fordc51
Jim
Cumming, Ga
Thanks for the suggestions. Do any of you using Ford bed mats and tailgate mats also have spray in bedliners ? In case I do a spray in later. Im also considering Ford spray in liner- $1k at my dealer. Im older and wont be doing a lot of hauling, but want to protect the bed when I do.
Ron Quixote
America
Several
My recommendation would be to have an independent shop to the liner. Line-X Premium is $799 at most shops and is an extremely nice product.
I consider getting a mat every now and then just to make it easier to clean out Even though I have a factory spray in liner.
i had linex in my last truck for 23 years and it looked good
Bt_okst
BT
Ok/Colo
I had a factory bed mat over my spray in liner, but saw a triplealiner on here and got it. I like that it has a two inch lip and would better let you slide things then either the factory bed mat or spray in liner.
mrmike7189
MA
2024 ranger STX 4x4
I got the Ford oem rubber bed mat from ford for $150. It works fine. Saves my knees when I'm on the bed floor loading stuff and it saves the paint from scratching. If not getting a bed liner , this is a good option.
Gregory
2025 Ranger Lariat
I have a spray in that was installed by my dealer's body shop as part of the sale. The price they charge was $600, I think. It turned out great. On top of the spray in I have a TripleAliners mat and Lasfit tailgate mat. I like those mats. They match, and seem to be the same material. TripleAliners has been posting discount codes in the forum.
fordgt
I have the factory spray in liner and the FORD mat on the floor. That mat is really heavy. I take out a couple times a year, it about kills me getting it back in.
Jam25
Allendale Michigan
2025 Ford Ranger Lariat 2.7 V6 - FX4
I put in a WeatherTech bed liner on top of the spay in bed liner however the WT is a perfect fit so could have been used alone. If you want no slip, this WT is it.
Gris
You can buy the Ford OEM mat with your Ford Pass points (or whatever they’re called). It’s thick and grippy
I also picked up a Ford mat with points for my baby raptor and it is great
