Lower control arm bolt torque spec?
tisser07
Brandon
Phoenix, AZ
2026 Ford Ranger Raptor
Operations
All, I bought the Foutz lower control arm frame sliders. The install requires loosening the lower control arm bolt, rotating the flag out of the way, and retorquing with the truck on the ground. I have checked a few AI versions and they claim torque of that nut is between 350-380ftlb. Does anyone know if this is accurate or have a source to confirm this?
CaptAngry
Denver, CO
2026 RRaptor
Space Engineer
It is actually 550nm, which is just over 400ft.lb
It is a big honkin chonkin bolt. I just wrenched on it with a breaker bar until I couldn't move it anymore.
tisser07
Brandon
Phoenix, AZ
Operations
Thanks, I had actually come across that data point as well. Really appreciate you confirming. I may need to pick up a torque multiplier.
Why did you remove that bolt?
CaptAngry
Denver, CO
2026 RRaptor
Space Engineer
yoopercharged
I needed to remove the strut assemblies to install leveling spacers
Are you referring to the lower shock bolt? I think OP is referring to the rear LCA to frame bolts?
CaptAngry
Denver, CO
2026 RRaptor
Space Engineer
Huh, you are right. I wasn’t actually reading the words… 😐
tisser07
Brandon
Phoenix, AZ
Operations
I'm waiting for Foutz to let me know the torque spec. I'll share it here once I find it. AI has been no help with this.
