NYMPHS
I asked ChaptGPT about the Method 703s I'm considering. Says I won't need hub rings.
If you're buying the Method 703 wheels specifically for the 2024–2026 Ford Ranger Raptor (17x8.5, +35 offset, 6x139.7 bolt pattern), you should not need hub-centric rings.
Here's why:
- Your 2026 Ranger Raptor has a 93.1 mm hub bore.
- The Ranger-specific Method 703 uses a 93.25 mm center bore, which is intentionally just slightly larger than the Ford hub (only 0.15 mm of clearance). Owners have confirmed these wheels are essentially hub-centric for the Ranger Raptor.
- Because of that very close fit, Method does not specify or include hub-centric rings for this application.
Yes with the tolerance that close you don't need hub rings. Plus with it being so close hub rings can't be made, not enough material. As long as your tires are balanced correctly being off a little bit will have no effect. I have yet to install my hub rings and there's no vibration. But still will add when I pull the wheels back off.
