Most Aggressive Wheels Offset Without Any Mods?
be.jammmin
Olathe, KS
2024 Raptor Ranger
If I wanted to keep the stock suspension height but wanted a wheel close to flush, what offset is everyone running? I am wanting to go with a +19 offset and a 285/65R18 toyo open country tire. Wheels are 18x9. However, I really do not want to make any modifications to accommodate that. Any thoughts are appreciated. Thanks, B
rwolfcastle
It depends what you mean by "flush". I've asked this question before and didn't get an answer. If you want the sidewall to be flush with the top of the fender, then I wouldn't go below a +30 offset.
If you are fine with a little poke of the sidewall, but the tread is flush with the top of the fender, then you are good with a +20 offset.
Here is a pic of my wheel (+20) and how it compares with the top of the fender. This to me is the perfect offset.
Ford Ranger Most Aggressive Wheels Offset Without Any Mods? IMG_7844 Medium
be.jammmin
be.jammmin
Olathe, KS
2024 Raptor Ranger
Thanks. With your +20 offset do you have any rubbing?
gstahl
Geoff
Denver, CO
24 Ranger Raptor, 20 F-150 Raptor, 23 Taycan GTS
Software
It would also seem that a 25mm spacer on stock rims would get one the same sidewall flush. Am I thinking about that correctly (like the wheels might go for a small spacer)
garagesale
Jon
CA
With 1” spacers, was it necessary to trim either your front or rear lugs?
famous47
Orlando, FL
Great info! I've been looking at the Roush wheels (+25mm). You mention no rubbing, do you think there's any possibility of rubbing with mud flaps on?
rwolfcastle
No, there's plenty of space in there.
Mgrmax
Detroit
Please don’t take my question as condescending. Do you have any evidence of failure with quality spacers? I see a lot of posts against using spacers and have seen pics of failures while using inferior products. I have yet to see failures with the quality spacers. Not doubting you. Just curious.
