MyView Resets
Canoman
DFW, TX
2025 RR, Carb-Gray
Chemical Engineer
Mine loses all my gauge selections every time. Seems like they only stick around a day or two. My RR is my daily driver.
CaptAngry
Denver, CO
2026 RRaptor
Space Engineer
And this morning it did it again. I hope whatever demon is causing this doesn't stick around because that is annoying
MarcR
CA
Ranger Raptor 25'
I hope everyone submits the feedback within infotainment system to get some what of an attention to Ford. A bit absurd this is happening this frequently in 2026.
raptor5244
Gregg
2026 Ford Ranger Raptor
Same here, twice in 2 weeks of ownership. I wonder if the Sync system does some sort of sync to the cloud every so often which sets these MyViews back to defaults? Truck is brand new, battery strong, no mods. I can try toggling off automatic updates to see if that plays any role. It is not getting an update but I wonder if it checks for one in the background maybe it resets some defaults? Either way, it is a bug and they need to address it.
RaptorDJD
D
South FL
2025 Ranger Raptor, 2014 Frontier Pro4X
It seems like this is a well documented thing with the myView. On a different thread, Specularius stated that his 26 Raptor did not have the Ford Built Tough splash screen activated from the factory. Another member with a 26 also stated the same. I wonder if it was turned off as it is interfering with the MyView settings. I thing I am going to disable it and see if I lose my settings. I am really getting sick of having to rest the cluster.
pablo94sc
Focus
Mine fully reset multiple times during the last month, including the 2 customizable gauges in the top row and reseting the screens in My Gauges. The only time I recall that happening before was after writing updates with FORscan. Maybe that's a clue.
OxygenMask
Phil
Eugene, Oregon
Mines does this randomly. Maybe not for days, maybe 2-3 times a day. Even forgets the R button preferences .
Never been to the dealer, never touched with forscan...
RaptorDJD
D
South FL
So I disabled the "Built Tough" splash screen on the cluster. I will update if that fixes the Myview reset problem or not. Time will tell
RaptorDJD
D
South FL
So just an update, So far, since I disabled the "Built Ford Tough" startup screen, I have not lost my setting on MyView. However, I am not saying that it fixed it yet because it is still too early to know for sure. You guys know how it is. It can be fine for a week then without any warning, reset twice in a day. Time will tell.
bvxz0138
west bend WI
IT
RaptorDJD : how did you disable that I’m not seeing it anywhere in the settings. Do you think this resolved the issue?
RaptorDJD
D
South FL
This is what I changed using Forscan: IPC 720-03-02 is xxx7 xxxx xxxx, which is Welcome/Goodbye disabled. So far, I have not experienced the loss of the presets. However, I have not driven my truck that much so time will still tell.
KrillOill
2025 RR
Update: I have noticed that my screen changes to another screen randomly. Seems to be when I switch from "normal" drive mode to something else. It doesn't lose my custom view, just moves to another view.
OxygenMask
Phil
Eugene, Oregon
Update: I have noticed that my screen changes to another screen randomly. Seems to be when I switch from "normal" dive mode to something else. It doesn't lose my custom view, just moves to another view.
Every drive mode has its unique screen. Is that what you're seeing?
RaptorDJD
D
South FL
Just another update 07-26-26. Nope. Did not fix the MyView reset problem. I just lost everything again this morning.
