ColeTrainsRR
Cole
Minnesota
E-Tec 3
When my turn signals are on they are a dead on match.
Ford Ranger New Ranger Raptor amber grill lights released by F150LEDs 20250929_034247
Ford Ranger New Ranger Raptor amber grill lights released by F150LEDs 20250929_034306
I am not 100% sure but I didn’t think I had any other amber lights on the front of mine, other than when a turn signal is activated.
DesertBumAZ
AZ
24 RaRaptor
InfoSec
Damn, was going to order these but they don't color match
The search for the perfect grill lights continues.
I even have 12V DRL pre wired to the grill...just waiting the correct product.
I want water proof, flush mount, color matching amber lights in the top 3 slots or 4 X Diamond shape for the top row Mid grill
Waterproof, UV resistant, quality cabling
Almost a grand slam F150 LED's but not quite.
hoping and waiting for @SPVPARTS comes thru with something awesome, I agree, that is orange, not amber and my OCD would be going crazy once i get the DRLs installed
bossy
Jerome
Bellevue, WA
I read quite a few comments and installation stories here. I do not understand what the exitement is about that 'new' 'improved' kit.
I am returning the grill kit back to them, as it does not fit at all. It sticks out from the 3 holes on the Raptor, especially the outer ones, despite their claim it does not.
When talking to customer service, they tell me to watch a movie I already did, that shows other units being installed, or rather another grill.
They would not refund the purchase, but only give me credit with a company I do not want to do business with anymore.
Sorry, this is not a good vendor and these are not people I want to buy accessories from... Look elsewhere..
I have both the originals and the new perfect fit versions.
They do not stick out. Not that I can see.
New perfect fit version.
Ford Ranger New Ranger Raptor amber grill lights released by F150LEDs IMG_4489
Old original versions. These really stick out and do not fit very well.
Ford Ranger New Ranger Raptor amber grill lights released by F150LEDs IMG_4492
Shadow Black Ranger Rapto
St. Louis, MO
I cut the plugs off and spliced them back in to avoid lager holes in the grill. The tape is the worst part in my option .
I did the same. Could not bear to drill that large of a hole to accommodate the plugs. Also tied off the cords on the back side of the grill.
bossy
Jerome
Bellevue, WA
Is it possible they sent me the wrong ones? It says Gen3 on the box..
I wanted to share those pics with you just in case it might help determine that very thing.
Based on your description, you were describing the original or non perfect fit versions that were pretty much just like you described, they stick out, they really had to be pried in there to get them in as far as I did on that first set.
I also had to remove the tape all together to jam them in that far.
That set was like $100 bucks, where the all new 2025 perfect fits were more like $230 bucks.
The extra cost was well worth it IMO. I have now tried 3 different sets of grill marker lights and this latest perfect fit set is by far the best ones I have found.
My first set was the cheap $50-60 set off Ebay from Chinna and while those slipped into the pockets easier, they were very dim and all the little diodes were visible when lit (DOTs) . Hated the dots loved the fit at that time since they were hidden.
I then went to the generic set from F150Led back in 2024 that I made fit, and those were much better-quality lights (much brighter and no DOTs) they just didn't fit as well as I would have liked.
Buckster
2025 Ranger Raptor, 2008 F150
Installed the new RR specific Amber Grill Lights from F150Leds on 2025 RR using the Headlight Accessory Connector. Lights look great and seem to be solidly built. I ordered the headlight accessory harness to not take up one of my Aux switches. . Even though it's called "headlight accessory connector" it connects to the side marker light not the headlight. I ran into a few issues with installation which I will share below....
DRILLING THE HOLES...As many have said here the hole size that you drill is huge compared to the size of the opening for the light. Even using several layers of painters tape and drilling a pilot hole, I still managed to scratch the crap out of the grill opening. I would suggest removing that part of the grill and drilling from the back. I tried drilling from the back with the grill in place and its too tight to get the hole in the right place so to do it properly drilling from the rear you need to remove that portion of the grill.
SIDEMARKER WIRING HARNESS. (Headlight accessory connector). Feeding the wires to the side marker are a challenge. I tried doing it per the instruction video and could not get the wire to the side marker opening. I ended up using a fish tape which made it much easier. Once connecting the accessory harness to the factory side marker connectors make sure you hear a click so that it's locked in place. If you dont hear the click you may have to lift up on the locking tabs which I had to do to get it to lock in place.
INLINE FUSE ISSUE. Once everything was connected the grill lights did not work. Flipped the black and red wires in the included quick connectors on the accessory harness and it still didn't work. Retraced all of my work and found the inline fuse connection on the included wiring was defective. I replaced the 5 amp fuse and swapped the black and red wires in the quick connectors and finally got it to work properly.
Ford Ranger New Ranger Raptor amber grill lights released by F150LEDs IMG_2778
Ford Ranger New Ranger Raptor amber grill lights released by F150LEDs IMG_2777
Ford Ranger New Ranger Raptor amber grill lights released by F150LEDs CLICK TAB
Ford Ranger New Ranger Raptor amber grill lights released by F150LEDs IMG_2779
Mattsraptor 2025
Europe
2024 Raptor
Had the same issue!
Just bought a 4th light and fitted them below.
Ford Ranger New Ranger Raptor amber grill lights released by F150LEDs IMG_2286
NASSTY
ME
I removed the grill and drilled from the back side. It only took about 10 minutes to remove.
Had the same issue!
It ended up he had the $100 generic light kit, which does not fit well.
I think he got it worked out to get the correct perfect fit kit.
The perfect fit kit, does fit perfectly into those 3 holes .
