Not simple to check tire pressure…..help.
rrrtx
Randy
lubbock, tx
optometrist
Somehow I missed the class on this one!! Big fat fingers can’t reach air valve without removing ring lock, and even then air value is difficult to add pressure or lose pressure. Are there some type of extenders everyone has but me??
A lot of work removing all the wheel ring screws that have lock tight on all 12 screws? Help?
stuartmunto
Stuart
Perth, Western Australia
2023 Ford Ranger Raptor
rrrtx
rrrtx
Randy
lubbock, tx
optometrist
KayaPayaPigDog
Kyle
www.youtube.com
US Navy
Air valve extenders are certainly an option but have potential to leak. My recommendation is a pair of needle nose pliers to help with the valve covers and a good air chuck that grabs on really well like the lock-n-lube air chuck.
got3fords
James
Central Va.
Resurrecting this as I went to check my tire pressure for the first time, and I could not get the valve cover off. Did you end up getting the extenders? How are they as far as being leaky?
Easy peasy on the Lariat:LOL:
PA RR
Mark
White Haven Pa
That was one of the main reasons I got new wheels!! Hated how hard it was to check air pressure!Also hated the +55 offset of the Beadlock wheels.
Caneman88
Ron
2025 Ranger Raptor MB GLC 300
Pella
I saw a post on here where someone notched the ring to make it easier to get to the valve
Pic-N-Stick
Northern Virginia, USA
Retired Firefighter
RaptorME
Maine
Um, a pressure gauge/inflator isn't going to help him get his fingers to grasp the valve stem cap.
26RRAvalanche
Columbus, OH
2026 Ranger Raptor - Avalanche; 2022 Acura MDX - PWP
Know what you mean, had the same issue on my 2019 Gen 2 Raptor with the 37 PP beadlocks. Royal PITA to get to the valve stems and I tried 2 different types of extenders and neither one worked. No more beadlocks for me.
got3fords
James
Central Va.
I found some valve extenders I had stashed away from who knows where. They work great for checking the pressure. They were different sizes, but just a short one worked and didn't look stupid. Had to use a needle nose pliers to loosen the caps. I am going to try a set of similar length from Amazon and give them a try, they're cheap.
Caneman88
Ron
Pella
I got new wheels now but yes factory with beauty ring was hard got this on Amazon it works well you need the straight air nozzle Air gauge
Ford Ranger Not simple to check tire pressure…..help. 1778180696105-ac
Ford Ranger Not simple to check tire pressure…..help. 1778180764720-4f
