OEM exhaust tips painted black?
got3fords
James
Central Va.
I really wish my RR came with black exhaust tips. Is there an easy way to blacken the factory tips without having to actually replace them? Would black spray paint work? I don't want to make it look worse.
CaptAngry
Denver, CO
2026 RRaptor
Space Engineer
I think a few members have hit them with a high-temp black paint. To spray them I think you'd need to drop the exhaust down by removing a few hangers.
OxygenMask
Phil
Eugene, Oregon
Also note, the factory tips are brushed stainless, not chrome.
Get em clean and spray em, no scuffing needed. Should be fine. Easy to touch up if needed.
got3fords
got3fords
James
Central Va.
I have high heat black rustoleum (for another project). Maybe I'll give it a try. Could always just touch it up.
some_guy
some
florida
entrepreneur
High Heat Rustoleum black spray paint, emove the rubber isolators and drp the exhaust, tape off the areas, and have at it. its fairly easy.
or you can buy black ones
got3fords
got3fords
James
Central Va.
Heat resistant silicone pipe 3.5" ID off eBay.
Slide on using liquid soap detergent. These have been on for 24,000 miles, no issues.
Great idea! Looks like you left about 1/2" overlap on the end? Not sure I am finding what you have, can you share a link?
celtic
glenn
Cut to your preferred length. I left a little overlap as it looks cleaner.
Ford Ranger OEM exhaust tips painted black? IMG_2782
got3fords
got3fords
James
Central Va.
Thanks, that's exactly the kind of easy mod I like.
celtic
glenn
Before I installed them. Painted the outside and ends in Plastidip as I wanted a Matt black finish.
Ivan Baez
Ivan
Queretaro
2023 ranger raptor
Harman
I painted mine black with high temp paint and they have been like that for 3 years now, no issues. I like the looks much better than the stock natural silver look.
morahn
Wi
2025 Ford Ranger Raptor
Started with a High Heat Primer (do not recall if I did any light sanding first, I may have done a 1000 grit but do not remember) then many layers of the High Heat Ceramic Coating (Flat Black) and painted pretty far up towards the rear axle (not just the tips). Sprayed as many coats as it took to empty the can (I think it was 5 coats).
Ford Ranger OEM exhaust tips painted black? 20250904_132930
Ford Ranger OEM exhaust tips painted black? 20250903_125023
Had a huge plastic bag from a queen size mattress that I wrapped the back of the truck with (including underside and tires) and had cardboard on the garage floor for drip and overspray (I am OCD and sprayed the exhaust in places that will never be seen).
Ford Ranger OEM exhaust tips painted black? 20250903_070954
some_guy
some
florida
entrepreneur
just be sure to also drill the drain hole to match so you dont have stagnant condensate in your system that rusts it out quicker than it should
got3fords
got3fords
James
Central Va.
Good point, noted!
got3fords
got3fords
James
Central Va.
so you dropped them down and then painted them?
