Oil Filters
Chuck2001
Montreal, Canada
25 RR, 24 Golf R
I buy the made in Brazil filter whatever the brand because it's the OEM. Made by Mann-Hummel/Wix.
Got the same conclusion as.the YouTube guy.
Whatever cheaper and more available around you.
TurboRanger
Jack
Oakley , Comifornia
Retired Truck Mechanic
I threw a rod on my F150 and Ford wanted to see all receipts for the oil filters
and they were all Motorcraft then wanted to see receipts for oil and when it was changed
Trimjb
Tennessee
2024 Ranger FX4
I understand the keeping of receipts which sometimes I'm negligent of doing.
So far I am only using Ford filters and oil while under warranty. Not sure if that makes a difference when it comes to warranty issues.
Can't oil change intervals be tracked in the oil monitor system if they really wanted to know what milage it was done?
Chuck2001
Montreal, Canada
25 RR, 24 Golf R
TBH, I'm used to German premium cars, first Ford, and used to specific oil / filter checks. As long as I'm using the right spec oil filter and oil (not necessarly the brand) and I keep the receipt and logging when I do an oil change (and reset the interval), if they would use that against me, they would never see me back as a customer ever.
I would repair the truck and sell it away, and turn the page.
Buellsox
Tacoma, WA
Local 26 Union Plumber
Honestly do it however YOU want. Just by no means exceed Fords intervals or get outside of their specs on the oil.
Doing a “break-in” change or 2 before 5K certainly won’t hurt anything and probably will only help, but who really knows.
Somebody could have engine trouble at 40K that’s over the top on their maintenance and then you could have the engine that gets zero attention and runs for 300K. Like the heavy drinker/smoker that lives to 100 and the triathlon freak dead at 55. Sometimes it’s a total crap shoot. But at least you can’t blame yourself if you do what you think is right and feel comfortable with investment wise.
Law of averages & opinions say 5K or 12 months max, factory Motorcraft filter (or equivalent), and a quality full synthetic oil that meets Ford’s specifications and you should be golden. I’m on the side of a couple of break-in changes before 5K so that’s what I’ve done, but I don’t preach it and don’t pass judgement on anyone that thinks it’s overkill. To each their own!
It’s your money and your investment so do it how YOU want to do it. You should know what feels like excessive on both sides of the spectrum so just settle into what feels good to you.
Just try not to be cheap, but there’s no reason to be wasteful either. My 2 cents…
Chuck2001
Montreal, Canada
25 RR, 24 Golf R
3k / 6 months full synth... And I do so much custom work at my dealer. They are super cool. I think they would be on my side.
av8r
NY
They’re bean counter engineers, there job is to always get you to spend money in the repair shop at the ford dealer.. After break in my OCI will be 4k miles
You have no idea what you're talking about. This is the same old parroted bs my dad and grandfather used to spout off about.
av8r
NY
If you want actual data from scientists to determine what the best interval is for YOUR truck, send a sample in to Cat or Blackstone or whatever lab you like. Then send in another one on the next oil change interval. They'll tell you how much of the additive pack is left which is what determines (mostly) when oil should be changed. After a couple samples have been analyzed, you'll have a data driven oil change schedule that isn't a stranger's opinion on the internet.
yerkool
Warren
SoCal
2025 Ford Ranger Crew Cab FX4
I’m an electronic technician by trade for almost 3 decades, work along side engineering dealing with RF, digital/analog units I’ve also work along side design engineering team, that dealt with Lockheed Martin, as well as General Dynamics, Raytheon. I know a little something working a long side engineering..
OxygenMask
Phil
Eugene, Oregon
2025 Ranger Raptor, 2012 F350
Speaking of oil filters, where the heck is it? I expected it to be inside the ds front fender well just above the frame, but I sure can't find it. Unless maybe I have to remove the fender liner?
2025 Ranger Raptor.
2025 Ranger Raptor.
It's the cylindrically shaped canister with the Hex with a cross on top. This is a 2.7 but same location for the 3.0. Study up on the procedure.
Ford Ranger Oil Filters 20250219_163549
Chippewa76
Midwest
Ford Car, Truck, & SUV
Check out the similarities on this video.
Just did my first oil change and installed a drain valve.
The valve is a copy of the Ronin valve. Well built.
You will find that fat small “O” ring can be a booger to change out. See my post over at maintenance on how to change it.
Remember to use “clear flood mode” to fill the oil system.
Good luck with the chynese illegal copy of the Ronin plug that saved you $10.
HyperM3
Lawrenceville, NJ
OxygenMask
Phil
Eugene, Oregon
Thanks! :thumbsup:
