Pro trailer back up set up
stormrider151
joe
Atlanta Ga
2024 ranger XLT, 2018 F250 SD
Retired firefighter
I hooked up my trailer and took it to a open parking lot to setup the pro trailer back up.
The sticker is placed properly and I made sure the camera was clean. I started the process with the on screen instructions and it would start the calibration.
The problem is it would give a notification that it could not see the trailer and then cancel the process. I must have tried it 20 times. I deleted the trailer and reinstalled it to no avail.
This one has me stumped. Has anyone else run into this? I really don't need it but it's there so why not.
Thanks a bunch.
What are the details about the trailer? Were you trying to calibrate at night? Is the full sticker between 4" and 19" (I think) from the center of the trailer ball? Is the full sticker visible in the rear camera view?
stormrider151
stormrider151
joe
Atlanta Ga
Retired firefighter
It's a 5x10 ft landscape trailer. Attempt was made in daylight. Yes the sticker is in the proper location. The sticker is clearly visible to the camera. I thought I might put another sticker on the other side of the tongue.
kkger
Usa
25 ranger lariat
What kind of drop do you have on your hitch. My trailer was slanting upwards towards front pretty significantly with a 2 in drop and couldn't get it to initialize. A 3" & 4" weren't enough so i had to get an adjustable one and it's set at 5"ish. Made my 6x16 utility trailer level and was able to calibrate. Patience and a really big parking lot help a lot too. I remember having to do about a dzn attempts to successfully calibrate.
av8r
NY
Never even knew this was an option on my truck, lol. Just back it up if you know how.
el_sabio
Randall
Tennessee
24 Ranger XLT FX4
Man, takes longer to turn on and get going than to just back trailer manually. It’s slick, but useless for me. I’ve been trailering for decades.
That said, my teenage son dominates with pro backup assist. It’s like a video game.
In answer, it’s been hit or miss for me. Sometimes the system doesn’t recognize my trailer, and like you, can’t figure out any reason why.
Shadow Black Ranger Rapto
St. Louis, MO
It is helpful for really short wheelbase trailers that can be especially twitchy like stump grinders and wood chippers.
HotPepperLariat
Rod
Appomattox Virginia
VW Touareg
Thanks a bunch.
Same here. I have a 17' Casita TT and tried numerous times to get it clalibrated. Tried during day, triple checked the stickers, tongue is level, deleted/reinstalled, etc. Just gave up. I've been towing it for 21 years with other vehicles just fine though so I really don't need this high tech gizmo. Frustrating though.
stormrider151
stormrider151
joe
Atlanta Ga
Retired firefighter
I'll have to check that. I have a weigh safe adjustable hitch. Worth a try. Thanks.
JR RANGER
JR
Auburn CA
2024 Ranger XLT FX4 4x4
Thanks a bunch.
I had to continuously turn in a steering wheel locked out before it would calibrate. Then the samevturning the other direction. Was frustrated too until I did that. My trailer was a 6 x 10 too.
JRRANGER
RHIPDX
Richard
Oregon
Ranger 2021 and Ranger 2026
I just calibrated mine. Took a lot longer than expected. In fact I had to go find an open parking lot to drive around in a fixed circle in each direction. Lost the trailer. few times, I think when one of the stickers got hidden by the front wheel jack motor. I presume you can actually see the stickers in your rear view reversing camera the whole time? My stickers were at the far end of the 4-19" range due to plates and bolts on the trailer arm. Not sure it that made it better or worse...
stormrider151
stormrider151
joe
Atlanta Ga
Retired firefighter
I think I've figured out the problem. When I make the turn the jack blocks the view of the sticker. Did you use two stickers? I think I'm going to try a second sticker on the other side and see if that does the trick. Thanks.
RHIPDX
Richard
Oregon
Yes, I put stickers on both arms of the trailer
kkger
Usa
25 ranger lariat
JRRANGER
I thought i started in a big enough lot but didn't have enough room for the long ass turns. Went to a bigger lot and zipped through it on the 1st attempt. Need a lot of real estate for the turns.I have a cdl so I can back the trailer up in an s, but I want to know how all the stuff I bought on my truck works. Maybe it would help my wife or daughter but I agree it's not a fast solution if you have the ability to it yourself.
JR RANGER
JR
Auburn CA
No just one
The stickers are supposed to go on the top of the tongue bar. Not on the sides
