While home from work i decided to attempt the install of this coolio ranger rapter grill that is made for the regular ranger. I got it from www.ycarpart.com for 226.88 with free shipping. I order it on 24 jan and it got here on 3 feb, though it comes in two packages and the first package got here 3 days ago.
My father-in-law liked it so much that he ordered it on 25 jan and his got here the day before mine, oddly. We have the same color trucks though his is a 2025 xlt with the fx4 package. He has a slightly smaller lift than mine and he has black wheels and aggresive off road tires.
So, onto the pictures.
Ford Ranger Ranger Raptor grill on regular Ranger - DIY install with pics 20260204_092334
Pop the hood and remove all these little push pin holders.
Ford Ranger Ranger Raptor grill on regular Ranger - DIY install with pics 20260204_092343
Ford Ranger Ranger Raptor grill on regular Ranger - DIY install with pics 20260204_093317
There are 13 to remove. Use a plasric trim tool to get the center up and then you cam just pull them straight up amd out of the part that covers the top of the grill area. I used the handy tool that came with my muslogy mud flaps.
Ford Ranger Ranger Raptor grill on regular Ranger - DIY install with pics 20260204_093331
You should be here now
Ford Ranger Ranger Raptor grill on regular Ranger - DIY install with pics 20260204_093359
Ford Ranger Ranger Raptor grill on regular Ranger - DIY install with pics 20260204_093402
Remove these two bolts from top of the current grill on your truck. They are 8mm, or 5/16". Same size is how it seemed to me
Ford Ranger Ranger Raptor grill on regular Ranger - DIY install with pics 20260204_093759
Grab here and pull straight out to pop the wing bracket out of its holder.
Ford Ranger Ranger Raptor grill on regular Ranger - DIY install with pics 20260204_093808
Do the same thing to this one.
The next part was tough and i didnt get a good picture. Its where you actually remove the grill from the truck. There are 8 more brackets across the bottom side of the grill that need to be pulled out. 2 of them are situated on their sides and are in the curved up area of the bottom of the grill. The two on theur sises will come right out of their attachment slot but the 6 across the very bottom are a pain the ass. I broke 5 of them and i was awate they were there and how to get them out. I just couldn't get then to pop out, even using a little tool to try and disengage them. Finally i just said screw it since i am replacing the grill, anyways. It just means i cannot sell the oem grill for a decent price now, though it still has enough clips to mount solidly. So thats why no decemt pic
Ford Ranger Ranger Raptor grill on regular Ranger - DIY install with pics 20260204_094639
The clips go into those thin slots at the top of the bumper. You will be here, once you get the grill off.
Ford Ranger Ranger Raptor grill on regular Ranger - DIY install with pics 20260204_095630
Next, you need to get the little brackets from one of the plastic parts bags that came with the grill, and the bag of screws, and put a bracket on each end of the grill. 2 screws per bracket. I took the blue tape off the oem grill smd put it in place on the new grill, just because ford had it on there for some reason.
Ford Ranger Ranger Raptor grill on regular Ranger - DIY install with pics 20260204_102046
I used bright colored screws so you can see everywhere that needs screws, behind the O and R, holding the led lights in place, and holding the flat top pieces on.
Ford Ranger Ranger Raptor grill on regular Ranger - DIY install with pics 20260204_102548
I used small zip ties to hold the wiring for the leds in place because if you dont, the wires just flop around and i was afraid they would get abraided and possilby short out over time.
Ford Ranger Ranger Raptor grill on regular Ranger - DIY install with pics 20260204_103219
Hold your new grill up and push all the clips into their slots on the truck. One at each headlight and the 6 across the lower section.
You are almost done and can see how cool it looks now
Ford Ranger Ranger Raptor grill on regular Ranger - DIY install with pics 20260204_104054
Runnthe led wiring harness along the factory harness and zip tie them tigether so the new harness doesnt wiggle around and short out or get cut somehow.
Ford Ranger Ranger Raptor grill on regular Ranger - DIY install with pics 20260204_105755
Reinstall the top piece with the 13 push pins. One of the front right ones that is closest to the middle will require you to push the plastic pieces its holding together so it seats properly. The rest drop in perectly.
Ford Ranger Ranger Raptor grill on regular Ranger - DIY install with pics 20260204_105811
I have the led harness zip tied up while i try and find a better why to hook it to the day time running lights then cutting and solder/shrink wrapping it to the truck wiring harness.
Ford Ranger Ranger Raptor grill on regular Ranger - DIY install with pics 20260204_132347
You are now complete.
Go have a snack and drink and wash your super cool truck that totally stands out from the crowd, now
I had to remove my license plate holder to do this. I forgot to add that, and also that those two 8mm bolts are not used on the new grill. I have no idea why but there is no way to reinstall them on the new grill
I watched this video to get an idea of what i was getting into
RRXLT
Roy
Waelder, Texas
2000XLT 2025XLT
That looks great! Thanks for the write-up and the pics.
Is that the EGR hood guard and are you pleased with it?
It is the egr guard and its been great. On over a year and never had a bit of trouble with it flapping or moving. No cracks and tons of bug splats on it after trips
spazzyfry123
North Georgia Mountains
Nice! Is this an "actual" Ford grill or something that is made to fit a non-Raptor?
I ask as I wonder if the inverse could be done to put a non-Raptor grille onto a Raptor.
Its an aftermarket manufacturer
I found out two web sites sell an adapter to plug into the light harness instead of doing any cutting.
F150leds is one
some_guy
some
florida
entrepreneur
I would do that and add some stamped steel wheels. I already removed the obnoxious badges. It would be so funny
spazzyfry123
I live in Camp Subtle (I know, I drive a RAPTOR), but I think it was day two of owning that I peeled all the stickers off. Hell, I was apprehensive on purchasing the Ford mudflaps because the rear ones say "Ford Performance" on them. I don't think the Raptor front grill looks bad, but I've always wondered if something like a Tremor grill or something would work.
some_guy
some
florida
entrepreneur
I have the Weathertech mud flaps. They are slight bigger than the Ford ones, the same material, easy to install, not flashy, no badges.
if you were nearby, we could sure try it. i don't know why a regular grill wouldn't fit though, looking at pics of the two trucks and the grills, its not the grill that wider, or headlights, so i think you can swap them.
(Edited for correction) no- go. See below for front view showing difference in front ends showing oem raptor wont take a standard ranger grill
i have only seen two ranger raptors in real life and both times they were driving so i cannot do in person comparisions.
I am wrong. I got to see one in person and actually look at it up close. I didnt look at the front though
ShadowDragon24
2025 Ranger XLT Fx4
Heavy Equipment Operator
F150leds is one
theres a marker light blunt cut wire under the bcm/trailer module behind the driver side kick panel.
theres Ignition, marker, and highbeam trigger wires.
Ford Ranger Ranger Raptor grill on regular Ranger - DIY install with pics Screenshot_20250922_091559_Adobe Acrobat
Ford Ranger Ranger Raptor grill on regular Ranger - DIY install with pics Screenshot_20250922_091636_Adobe Acrobat
Ford Ranger Ranger Raptor grill on regular Ranger - DIY install with pics 20250822_150423
Ford Ranger Ranger Raptor grill on regular Ranger - DIY install with pics 20250822_150451
ShadowDragon24
2025 Ranger XLT Fx4
Bumpers are different. and the curvature. pulled from fords website
Ford Ranger Ranger Raptor grill on regular Ranger - DIY install with pics Screenshot_20260208_002014_Samsung Internet
Ford Ranger Ranger Raptor grill on regular Ranger - DIY install with pics Screenshot_20260208_002033_Samsung Internet
