RC MUSTANG Azure Gray Raptor Build
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
1989 Mustang 2017 Fusion
Integrated third brake light chase lights.
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260709_151224
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260709_151244
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260709_151235
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260709_143104
shinnygray
TX
Tie down ratchet strap system.
Do you actually like it? I fell like the angle of the ratcheting is going to eat into the straps for anything that has to be strapped across the back of the bed.
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
I haven't actually used it but it'll mostly be for strapping across to the front. For strapping to the rear i haven't thought about that but I also carry standard straps.
Caneman88
Ron
2025 Ranger Raptor MB GLC 300
Pella
the light looks real good did it come as kit ? I did the glovebox light works real nice it should have come with it
what is the make/model of the 3rd brake light
thanks in advance!
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
thanks in advance!
It's a 3D printed unit complete with the lights. It's a pretty cheap setup but it does stick out quite a bit. I can't say compared to other ones or there but I'm guessing it's similar in size. The optional gasket they sell doesn't look like it seals a 100% so, I'm going to add a foam style one as well. I might even see if that alone works better.
https://printineeredlightingco.com/products/2015-2020-f-150-third-brake-light-chase-light
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
Lumens/candela/watts etc. what are the specs? Not listed on their site. They look like BD’s.
OK, I don't know. They are pretty bright even in daylight is what i can tell you. I'm pretty sure if you reach out to them they could tell you.
Caneman88
Ron
Pella
Options BD
S2 Pro LED Auxiliary Light Pods or sport are the options
sport
Brightness (Lumens) 1581
pro
Brightness (Lumens) 2245
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
Found a rare key it yourself spare tire lock set. You can only find one that come pre-keyed with another key instead of using the one already in your key fob. Now i know how to key these lock cylinders.
Ford Ranger RC MUSTANG Azure Gray Raptor Build Screenshot_20260715_151709_eBay
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260715_150427
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260715_150539
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260715_150520
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260715_150513
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
Credit to @Gman10 for discovering the one touch auto windows for the rear was just removing the stops on the switch. I was able to do it without removing the switch covers. I went all the way and did the rear switches as well. You use a screwdriver to pry the 4 retaining tabs while pushing the switch in for the rear. The front is held on with 3 small torx screws.
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260804_222101
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260804_222840
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260804_222844
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
Already knew the hood heat extractors were functional but turns out a quarter of them are blocked by the foam. Opened up the hood liner insulation to help more of the heat get drawn out of the engine bay without any water intrusion.
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260809_135225
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260809_135342
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260809_140152
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260809_140136
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
Velossa Tech Design Intake Scoop. Removed a few of the reinforcements to remove obstructions. Added some weatherstrip to seal and keep the air more directed to the intake. Added a couple washers to the shutter simulator so it doesn't bind and allow for free opening and closing of the shutters. This should lower the intake box temps and possibly increase mpg a bit like on my last Ranger and Fusion.
Ford Ranger RC MUSTANG Azure Gray Raptor Build Screenshot_20260819_184544_Chrom
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260819_183417
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260819_132842
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260819_183432
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260819_181735
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260819_172531
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260819_182334
RCMUSTANG
RCMUSTANG
Ray
Los Angeles
The transfer case skid plate finally arrived.
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260904_154047
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260904_152235
Ford Ranger RC MUSTANG Azure Gray Raptor Build 20260904_154028
