Rotational Chirping Sound - 25 XLT 2.3L
gtistiffler
Keith
Panama City, FL
2024 Ranger XL 4wd
Technician
They replace the whole driveshaft for something that just needed grease? What am I missing?
the crazy part is in the Bronco world there are guys that have had theirs replaced 3 or 4 times under warranty. My clamp and grease fix mentioned above is still noise free. You would think they would put out a kit for the dealer with two clamps and a packet of grease. Surely would be cheaper for them.
got3fords
James
Central Va.
Yeah. It just makes no sense to me!
camocustom
camocustom
Dan
Port Richey
2025 XLT 4x4 (Sport)
Any update on yours? Did the driveshaft solve the issue? My 24 RR has started making this chirping sound which sound identical to the videos posted on Bronco6G.
So far, its been about 800 miles sound free.
They replaced the whole driveshaft assembly, it was the slip joint causing the sound.
yoopercharged
My ‘25 Raptor started exhibiting this sound recently. Will have to bring to the dealer’s attention next time I’m in. Glad to at least know the source of it now.
Are you feeling any binding near lock in 2H?
gtistiffler
Keith
Panama City, FL
2024 Ranger XL 4wd
Technician
Just an update. My grease fix is still working. No noise.
ElectronNinja
Fredericksburg VA
2024 XLT FX4
24 2.3L here. 15k miles. I had heard something start clicking or similar around 9k. Up on the lift and couldn't find it...but the truck was also cold.
Now at 15.6k....clear as day chirping. I immediately figured there's a slip or u joint failing somewhere. Seeing this thread and all the Bronco guys suffering with the same part....sigh...I still haven't found a good local dealer either in VA.
The second dealer OP went to understands troubleshooting. The first were hacks.
Guess I go find a place now that doesn't have pinecones for wrenchers, get a front DS.....and then immediately get set up to grease it. Always the concern that if it DID run dry, then it may already be damaged.
I wager the factory is probably under greasing these to save a buck over thousands of trucks. Seen in many other industries.
ElectronNinja
Fredericksburg VA
2024 XLT FX4
Got back from a 1900mi moto trip.
First thing I did was yoink the shaft. No evidence of breached boots or grease fling.
Both joints felt like garbage. The CV joint at the diff has an inspection/grease port I put a borescope through. What little film was in there had carbonized from heat. The surfaces are ruined unfortunately....so I ordered a new shaft.
This being on a 2.3L which doesn't have an exhaust pipe next to the shaft either....so the long road trip last year was apparently all it took.
When the new one shows up, I'm adding more grease if they're still nearly empty.
TLDR, grease your driveshafts before they get knackered or just make Ford keep paying for new ones until they get tired of it I guess 🤷🥲
