Jeffola
Southwest Florida
Business Development
I use constant power into a relay with timer I purchased from Amazon. I have it set to automatically turn off after 2 hours, if I forget.
Do you ahve the link for the latching relay timer you used, AND where did you tap into for power source and how did you connect to the bed lights (OEM)? I so badly also want to do this. Why there's no bed light switch in the bed is MIND BOGGLING.
Danager
Dan
Alberta
Manager
I’ve run my own power back.
Here is the description for the module I added.
DC12V 0-120mins Adjustable Cycle Times Switch Module, Delay On/Off Timer Delay Switch Module
Tailwagger
Ron
MA USA
Not sure if it was mentioned already, but I just noticed this morning that in the lower center/right of the driver display next to little Raptor Icon the car displays the compass direction. Totally hadn't noticed it until today, figured others might not have as well.
for those with the smaller cluster, the compass is on top and you can enable it with forscan if you don't see it.
Fawnbuster
Indiana
This isn't a tip or trick but it sure is a secret to me...found this today under my back seat in the storage compartment on the driver's side. Wondering if it was supposed to be mounted in a Bronco ? I have all of my seat belts, this isn't configured for the middle jump seat in my RR.
So no one knows which vehicle this goes to???
Fawnbuster
Indiana
Fawnbuster
Indiana
Really surprised that there isn't an oem relay under the hood that can supply power.
jrRaptor
Maize, KS
Do you install over factory tint?
I did, I wanted 15% all around so they were able to get them all within 1 or 2% I think. I posted the numbers in one of the tint threads.
I installed the Techpicco hood struts. 10 minutes and I'm very pleased.
so do those lower brackets come with the strut kit or are they already on the truck?
i know i can go look but i will forget once i get out of work
NightRanger
Tod
Atascocita, TX
Field Service Engineer
