SuperPro Control Arms
ATestBishop
Walnut Creek, CA
2024 Ford Ranger XL
Certainly, you are well on your way, if anything does come up let use/me know and I'd be glad to help out if possible. I worked on a sloped driveway which I do not like but had to
I just had a set of these delivered. Once the other parts arrive, I'll be throwing them on. Looking over the installation instructions, they don't look too bad but I am a little unclear on the steering shaft.
Per the included instructions:
"3. The steering shaft needs to be disconnected to remove the UCA bolt. Start by marking the shaft with a marker so that it can be re-inserted in the correct orientation.
4. Remove the bolt that attached the shaft and slide the shaft back up towards the steering wheel so the joint can be moved out of the way."
They included a picture but it really isn't clear and the pictures appear to be for a right hand drive truck. Does the steering shaft need to be moved to get the UCA bolts out on the NA Rangers? If so, does anyone have a clearer picture or description of what needs done?
I bought Rough Country UCAs. The install process is the same. This is what you should see.
This is the installation instructions from RC. It may make things clearer.
Ford Ranger SuperPro Control Arms 1777737530555-0c
Ford Ranger SuperPro Control Arms 1777737569320-h1
keep in mind there are also two types, depending on knuckle material.
I don't think that applies to 6G. I wasn't asked about it when I got mine from Rough Country.
RB205
BB
Denver
XJ
I think he's talking about Superpro / Whiteline. They have stock geometry upgraded arms or ones that have an adjusted ball joint position for lifted front ends.
HighDesertRanger
Oklahoma
Ford Fusion 2.7
Sales Manager
White willy
Earth
2025 Ranger
Right, so does RC. 5G models came with either aluminum or iron knuckles, which is why you had to specify.
