Thoughts after our 8k mile trip to Olympic NP.
8k mile road trip over the last 3 weeks from Memphis to Olympic NP has me ready to put the truck under the knife, literally and figuratively. Here's what I learned.
First thing I noticed, the sag from the rack, tent, and gear. 300lb springs are going to be ordered soon, as sitting level-ish really screwed with my visibility, and adjusting the seat didn't help much as I couldn't seem to get it dialed in like before. Braking was slightly worse as well, but not sure how much of that was weight vs rake.
I want more clearance. Not a lot, but a spacer lift with 35s should allow me to take trails with a little less care for wheel placement. South Draw Rd, just south of Capitol Reef, is maybe a 4/10 trail, but the Raptor handled it fine with maybe only a couple small bumps on the underside. Another inch of clearance would make it a breeze. Bumpers are not an issue or a needed upgrade unless you plan to hit 5-6/10+ trails or mount accessories without a lot of fab work or cutting.
I need real sliders. I made a right turn too tight and got the PS running board hung up on a boulder ballard in a parking lot. I was able to crab walk the truck off the rock, but not before putting a new hole in it and realigning the running board. Kiddo didn't see it either, so I'm not a total idiot, just partial.
The Ark mid height splash guards I installed worked as intended and kept most of the muck off the truck. Definitely happy with them. That said, if you run poke and don't have splash guards, I hope you get kicked in the berries.
Intercooler has to be upgraded. The charge temps doubled from ~20F over ambient to ~40F over in the last two years. Could be full of bugs, but that's a pretty big jump from our roadtrip 2 years prior. Suggestions on the best bang for the buck here would be appreciated, especially if you have before/after temps with the new cooler. Looking for less heat soak and consistent, cooler temps.
Cold air intakes are definitely not needed. I never saw intake temps more than 4F above ambient, whether it was 100F or 50F out, no matter the speed or trail.
The grill shutters really effect cooling. Open with the AC on, coolant temps at the cylinder heads were easily 20F lower than AC off and closed. No real difference in gas mileage noticed, so not sure if these are even needed except in the winter to keep temps in the operating range.
The Wildtop rack I bought cannot be recommended at this time. I had my concerns before the trip and posted them here. After doing the Cathedral Valley loop in Capitol Reef, the clamps loosened enough to slide the rack forward a full inch with enough side-to-side shimmy that the rubber feet on the bottom rails came out. Also allowed the zippers to rub directly on the paint. I had to retorque the bolts every couple days the remainder of the trip. I will be removing everything in the next few weeks to redesign this thing to make it Raptor approved, and might even market my own version.
The AAL ditch brackets with antenna wings bounce around a lot with dual light pods installed on them. Everything is tight, so I can't recommend running dual pods on them unless you're okay with some jiggle. Probably fine with a single pod and antenna mounted as that's what they were designed for. That said, I'm thinking of alternate solutions for mounting ditch lights on our trucks. Hood glare is atrocious.
Speaking of the hood, this thing scared the crap out of me anytime we passed a semi on a two lane road at 60mph or above (the speed limits on some of these rural highways). I noticed it before, but this trip was more blue highways than intestate. The hood jumps like crazy and as best as I can tell, only the latch is preventing it from flying open. If you've seen this, you know what I'm talking about. I'm thinking that opening up the hood vents may help with the pressure differential. Thoughts?
The power ports in the bed are fantastic. Every day the 12v charged the Anker SOLIX C1000 1Kw power station and kept my fridge running and misc tent gear topped off.
https://www.ankersolix.com/products/c1000?variant=49702371524938
Caveat: this made charging stuff in the cab slow. Truck could probably use a bigger inverter or alternator if you're using a power station or second battery.
AC blower started getting weaker after playing in the desert, so I'm thinking it's time for a new cabin air filter.
Camp kitchen was mostly successful, but definitely could use some tweaks for better organization and usability.
Finally, I really think Ford dropped the ball only installing a 20 gallon tank on a truck that averages 15mpg loaded down for camping/overlanding. An extra 5 gallons would go a long way, literally, to keep range anxiety at bay. Instead, I filled up every 150-200 miles. My bladder thanked me, but seriously, what a PITA.
PS: strong tailwinds (>30mph) got me over 22mpg at 80mph in Wyoming. Similar headwinds netted ~13mpg at 80mph in New Mexico and Utah. Slowing down and riding behind semis @ 70mph netted about .5mpg improvement, but the savings didn't justify the distance lost.
I'll post pictures (edit:) in the next post.
Running board damage. Not bad, and it held the truck's weight, but I haven't gotten under there to see if anything bent yet.
Ford Ranger Thoughts after our 8k mile trip to Olympic NP. 20260622_133605
Ford Ranger Thoughts after our 8k mile trip to Olympic NP. 20260622_133614
Rock strike from a Tundra with poke. It's hard to see, but the lower circle is about the size of a golf ball.
Ford Ranger Thoughts after our 8k mile trip to Olympic NP. 20260622_134305
The rack. Wildtop can kiss my grits. I told them this was a bad mounting solution. The arrow points to a small gouge in the rail cap where the rack was originally located. Circled the rubber foot hanging out.
Ford Ranger Thoughts after our 8k mile trip to Olympic NP. 20260622_133707
You can sort of see the difference in zipper location in this one, but the lovely scratches don't really come thru.
Ford Ranger Thoughts after our 8k mile trip to Olympic NP. 20260622_133646
Clamps didn't look like this originally, either.
Ford Ranger Thoughts after our 8k mile trip to Olympic NP. 20260622_140401
Ford Ranger Thoughts after our 8k mile trip to Olympic NP. 20260622_140336
jrlrule
J
TX
Sounds fun! 8k road trip sounds crazy though. I drove from dallas to colorado last weekend for camping and I will say the hood flutter drives me crazy! I need to adjust it maybe but it looks flush with the fenders right now?
I also wish I added bug remover to the windshield wiper fluid (not sure how much it would help) but the regular washer fluid didn't do crap to them! More reason to stop at a gas station and clean them off.
And yes I wish the gas tank was large enough to get us to 400 mi highway.
It wasn't bad, actually, other than my lower back acting up after a couple weeks sleeping in the tent and random hotels.
My hood is about as good as it gets, alignment-wise. I think it's just catching a ton of wind and there isn't an exit, so to speak. I'm thinking opening up the hood vents like Dirt Derrick posted (https://www.ranger6g.com/forum/threads/indicarbon-vents.21236/#post-306893) will help a bit, but it may require removing some rubber gasket material along the lower windshield cowling. I didn't notice it every time we passed a big truck, so I'm wondering if I had the AC off those times and maybe the grill shutters helped. Pure speculation.
The rain x wiper fluid (orange) did help a tiny bit with bug removal, but that's only after having it sprayed heavily and often on a mostly clean windshield to remove dust and pollen. Might be time to play around with ceramic coating the windshield with some Adam's polish stuff before I get it replaced. Headlights too, as those got wrecked by bug guts.
I am 6ft but I have always preferred setting up higher in the saddle then the seat will adjust too.
I added these seat risers to all of my RRs.
The instructions show them raising the front of the seats but they also work on the back of the seat where I used them on my RRs.
Bloody run
Clearfield pa.
2025 Blue Ranger Raptor
Retired Harley Davidson Toolmaker
This just raises the front of the front seats correct?
Just looking at the tire to fender gap tells me you have no rake left. When i put my Honda Fourtrax Rubicon in the bed (751 lbs), I had about 1/2" of negative rake and definitely affected visibility over the hood! I notice a big difference in visibility. Now 200-300lbs in the bed evenly distributed wasn't an issue, just when I maxed out payload with over half of it in the bed.
I’ve never noticed any hood issues and I’m running 75-80 up and down I-5 passing semi trucks
Not like that. Think 2 lane country road. The semi is doing 65 going southbound in the oncoming lane, and you're passing him while going 65 heading northbound, with only the yellow line and maybe 6ft of air between you. That wall of air he's pushing hits ours and causes our hoods to jump and flutter. It's pretty intense to experience, even when you're expecting it.
Danny Dean
Danny
Oregon
2024 ranger raptor
Copy that, haven’t been doing any of that
No , I used them to raise the rear of my seats only. I didn’t install any on the front side of my seats .
You can place them in front or in back of the seats, fits and lifts either way.
Yeah, total trip payload was easily between 500-550lbs with 3 weeks of clothes and the rest of the camping/trip gear loaded up. What I'm most surprised about it is that we have very little we need to trim from our setup. Only thing we didn't use, that wasn't recovery or emergency gear, was our individual sleeping bags. Our 0F bag turned quilt kept us pretty cozy at 30F.
Edit: I guess I should be more surprised about how warm that tent can stay when fully zipped up. I fully expected needing our bags under the quilt when it got down to freezing. I think with a medium weight fleece blanket and a couple hand warmer packets, and that tent might be good to 10F before needing a heater or their insulation kit. I might need warmer sleeping mittens, though. Lol
RaptorME
Maine
Have those with hood flutter tried adjusting it? Just asking. I had to adjust it to close easier after adjusting my hood struts.
My 24 does not shake at all, my 25 RR drives me crazy fluttering in the wind, I have been playing around with the adjustments on it since I got it 6-8 months ago, still can't get it to set still like the hood on my 24 RR. I am about to give up and have the dealer take a crack at it soon as it needs an oil change or some other reason pops up to take it in.
I did order some hood struts I need to get installed and was in hopes maybe those would help in some way. Not counting on it, but thought it would be worth a try.
