Tire Temp - N.A. Forescan
Connman1
Has Anyone enabled the TPMS Tire Temp..? Need help with the Tire Temp..
I do not Understand the line,
IPC 720-11-01.. E.G. Suggest to use non-asbuilt menu to change *-> Bit 4 ( Add 8 to enable, e.g. change 2 toA),
Any help would be much appriciated..
CaptAngry
Denver, CO
2026 RRaptor
Space Engineer
Pretty sure I used the menu (aka the non-asbuilt), but it has been a while
What the note means is if you load the asbuilt (the one with all the HEX codes) you find entry 720-11-01, go to the second entry box, and add 8 to first digit. So if it is a 2, you add 8 which gives you 10 which is "A" in HEX.
So.... just use the non-asbuilt menu
Connman1
Its a little confusing...the way it is stated..Thanks for correcting it..
Yeah, pretty sure I used the drop down as well.
