Trail Turn
Stumpm2
Wyoming
Ranger Raptor, F350 Tremor
Trail Turn Assist on my Wildtrak, here is how:
Changes are needed in APIM and ABS module;
APIM 7D0-10-02 was 0000 00A2 00–, changed it to 0000 00A5 00–. This adds TTA button to offroad screen.
ABS 760-03-01 was E87C 56–, changed it to E87C D6–. This enables the TTA on ABS module.
After the changes, I have performed a short test on a not very suitable surface and it worked. If you want to give it a try, please do it on your own risk.
I also tried to activate the trail control function but I wasn’t completely successful. Changes are necessary on same lines but also in IPC I assume. As far as i understand, It seems like hill descent control and trail control doesn’t coexist so hdc needs to be disabled completely to have trail control. Everything I shared is experimental so do what ever you do on your own risk.
Tried to update my previous post and ended up deleting it. I did confirm today thhat the changes to the APIM and ABS module did add trail turn assist to my Ranger Raptor and it seems to work just fine.
APIM As-built 7D0-10-02 was 0000 0E71 0068 changed to 0000 0E75 00xx
ABS As-built 760-03-01 was F67C 7653 changed to F67C 06xx
mehmetmsm
Mehmet
Antalya
Next-Gen Wildtrak 2.0
@Stumpm2 would you share your VIN as private message?
I am trying to activate the Trail Control feature and it would be helpful to see the values on raptor asbuilt since raptor had trail control feature.
vivasjm
Juan Manuel
México
Ranger Raptor 2023
Employee
This is really usefull. I will try with my ranger raptor. Do you have any other mods that can be done in the RR with the forescan?
jrRaptor
Maize, KS
IndyBrett
Brett
Indiana
2024 Ford Ranger Lariat
EE
I have seen videos from Australia where the Turn Assist comes standard on their "Wildtrack X" model. I am sure they are testing it there before it is available here. My guess is it will be available here in the US when they launch the US Tremor package.
craigc
Craig
Allen, TX
I googled for a Ranger Raptor available on a lot a few months ago, got the VIN, and converted to CSV. Open the attached. (If you open in Microsoft Excel, choose "don't convert" to preserve the leading 0s)
I believe trail control is below. These were already enabled on my NA Lariat.
IPC720Trail Control720-10-01xxx*xxxxxx--
APIM7D0Off-road Menu - Trail Control7D0-10-02xxxxxxx*xx--
JustNick
Nick
BatonRouge
Shelter Green Ranger Raptor
SOLA Motorsports
Are you getting any notification when it starts to grab the inside brakes? I made these changes as well and I can't really tell if it's working or not
JimmyGator
Phoenix, AZ
2024 Ranger Raptor, 2022 Bronco Raptor
This is really interesting. Does who goes into the computer know whether the ProCal tool that some of us got with our Ford Performance Tune can be used to activate this feature?
Stumpm2
Wyoming
It only works at slow speed with steering wheel at full lock. You will hear and feel the inside rear wheel skid and you will turn on a dime.
Stumpm2
Wyoming
No, programming needs to be changed in the APIM and ABS module. Will need Forscan or FDRS.
kulvershtukas
Anton
Estonia
Guys, what should be changed exactly to activate Trail turn? On my Ranger Raptor I have following meanings:
APIM as built: 7D0-10-02 0000-0071-005A
ABS as built: 760-03-01 F27C-562F
I don’t get the logic what changes should be done.
vivasjm
Juan Manuel
México
Ranger Raptor 2023
Employee
For APIM As-built (7D0-10-02) we only need to change the 8th digit to 5?
For ABS As-built (760-03-01) we only need to change the 5th digit to 0?
what does "x" means? a value unchanged?
Stumpm2
Wyoming
The XX are the binary numbers to complete the line. They will be changed automatically when you write.
