The f150 and 5th gen rangers have the 10r80 while our 6th gen have the 10r60. I wouldn’t assume that they’d fit and work as intended, but it might be worth asking the manufacturer.I think eBay has these already for about $30. They are labeled for the F150 but I've seen someone install it on a ranger (might have been a 5th Gen but should still work for us).
The sucky part about it is it’s right next to the Catalytic Converter and you can’t check it while it’s hot and the engine is running,According to the service manual, it has a little baby dipstick with markings, you just have to get under the truck and do wrench acrobatics to see it!
My understanding is that the factory dipstick is the same but the target numbers are different. If nobody else does, whenever I get to changing my fluid, I'll be the guinea pig for $30. Mine isn't quite at 2k yet, so I have a little whileThe f150 and 5th gen rangers have the 10r80 while our 6th gen have the 10r60. I wouldn’t assume that they’d fit and work as intended, but it might be worth asking the manufacturer.
Always has had this. When vehicle is at operating temp it is difficult to access this. 19MM short/stubby wrench required to remove plug to access 'mini dipstick'. (Ford tech)According to the service manual, it has a little baby dipstick with markings, you just have to get under the truck and do wrench acrobatics to see it!
But you HAVE to check it with the transmission at operating temp. so has to be hot. which sucks. why I want Mikes when he finishes developing it. and then I want to get a slight deeper, and metal pan with drain plug to replace the plastic pan. lot of hills in my area. and now that I have bigger tow rig, I've been towing more weight.The sucky part about it is it’s right next to the Catalytic Converter and you can’t check it while it’s hot and the engine is running,
