Transmission oil dipstick for 2025-up Ranger 2.3ltr
yerkool
Warren
SoCal
2025 Ford Ranger Crew Cab FX4
Has anyone installed a transmission oil dipstick for the Ranger 2.3 ltr yet?
What’s available? can’t seem to find what would work for my late 25 early 26 Ranger 2.3ltr…
ShadowDragon24
2025 Ranger XLT Fx4
Heavy Equipment Operator
It's currently in development. Mike posted here in the forums not long ago, looking for local volunteer to test fit on their truck.
Sharpie223
E.Wa
In-between atm
I think eBay has these already for about $30. They are labeled for the F150 but I've seen someone install it on a ranger (might have been a 5th Gen but should still work for us).
The f150 and 5th gen rangers have the 10r80 while our 6th gen have the 10r60. I wouldn’t assume that they’d fit and work as intended, but it might be worth asking the manufacturer.
yerkool
Warren
SoCal
According to the service manual, it has a little baby dipstick with markings, you just have to get under the truck and do wrench acrobatics to see it!
The sucky part about it is it’s right next to the Catalytic Converter and you can’t check it while it’s hot and the engine is running,
Sharpie223
E.Wa
In-between atm
My understanding is that the factory dipstick is the same but the target numbers are different. If nobody else does, whenever I get to changing my fluid, I'll be the guinea pig for $30. Mine isn't quite at 2k yet, so I have a little while
b-smi91
Barry
Kenny Ross Ford
2025 Ford Ranger, 2.7L, 2023 Ford Ranger
Ford Technician
Always has had this. When vehicle is at operating temp it is difficult to access this. 19MM short/stubby wrench required to remove plug to access 'mini dipstick'. (Ford tech)
saxdogg
Jeremy
D/FW
2026 Ford Ranger XLT FX4
Yes. I would just drain from that hole when cool and fill the same amt taken out. Not everyone has a good sucky sucky pumpy pumpy tool, but hey good excuse to get one....it's pretty handy for lawnmowers, etc too
ShadowDragon24
2025 Ranger XLT Fx4
But you HAVE to check it with the transmission at operating temp. so has to be hot. which sucks. why I want Mikes when he finishes developing it. and then I want to get a slight deeper, and metal pan with drain plug to replace the plastic pan. lot of hills in my area. and now that I have bigger tow rig, I've been towing more weight.
