Transmission Shifts to Neutral on its own.
RichR
Richard
2024 Ford Ranger
I have a 2024 XLT, 2.3. Yesterday, the transmission shifted into neutral all by itself. I stopped at an intersection, and when I started to pull ahead, the transmission had shifted to neutral. The only way I could move was to go to the manual mode and shift manually. Reverse didn't work either. I turned the engine off and restarted it, and everything was fine. I went home without a hitch. I called my dealer this morning about it. They had never heard of that happening. They will be getting it today to check it out. Oh, I got a powertrain malfunction message.
Has anyone had this problem?
emcmtony
tony
swedesboro, nj
I have had a similar problem where the shifter moves from D or R to park and will not engage until I shut down. Did you take yours in? Mine is currently in shop
ChronciallyChronic
Central Florida
2024 Ford Ranger Lariat
I assume you have the e-shifter and not the mechanical one?
Wolfman00
matt
crofton md
2024 xlt
late reply, but was it determined what it was? mine has done this twice in past few months
AugPal
Augie
Chicago
Retired IBEW
I've read of this happening on other vehicles when the transmission fluid is low
RichR
Richard
2024 Ford Ranger
I had that happen only one time, nothing since. ?????
