Under Hood Sound Dampening
daytoncarter
Dayton
those usually are not actually noise/heat insulators. they normally are there in case of a fire. the plastic clips melt and the stuff drops on the fire to hopefully smother it. kind of like the plastic plug in the fire sprinkler system melting and setting off the sprayer
When did you make this up?
Ryder66
Ryder66
Chris
Ottawa, Ontario, Canada
2025 Ford Ranger XLT FX4 2.7 Liter Carbonized Grey
Did you get an answer from the dealer? I have the same "issue." I ordered an XLT 2.7 in June and delivered in September, and it does not have the sound dampening. I didn't even notice until I saw this post. From videos on 2025 Ranger XLT reviews, it looks like some have it and some don't.
I haven't had a chance to get to the dealer yet. I will post once I know more. Please do the same if you get to the dealer.
mrmike7189
MA
2024 ranger STX 4x4
He is correct. It is used for insulation ,sound dampening and in case if fire
Fire resistance
The pad is often constructed from fire-retardant materials, and the plastic clips that hold it in place are designed to melt in the event of an engine fire. This causes the blanket to drop onto the engine to help smother the flames.
daytoncarter
Dayton
I asked AI:
This claim is a very common automotive myth with no credible evidence to support it. While it sounds plausible, the under-hood insulation is not designed as an active fire suppression system.
Here’s a breakdown of the facts versus the fiction.
The Primary Functions
The main, universally accepted purposes of the under-hood insulation pad are:
  • Sound Dampening: Its primary job is to absorb engine noise, creating a quieter experience inside the car and reducing noise pollution outside of it.
  • Heat Insulation: It acts as a thermal barrier to protect the paint on the hood from the high temperatures of the engine bay. Over time, excessive heat can cause paint to fade, discolor, or peel.
Deconstructing the Myth
The idea that the insulation pad acts as a fire blanket is a piece of automotive folklore that gets repeated often in forums. Let's look at why it's incorrect.
  • Fire-Retardant vs. Fireproof: The materials used (often fiberglass-based felt) are fire-retardant, not fireproof. This is a requirement under Federal Motor Vehicle Safety Standards (FMVSS 302). It means the material is designed to resist catching fire and will burn very slowly or self-extinguish once the flame source is removed. It is not designed to actively put out a fire.
  • Melting Clips - Consequence, Not Design: The plastic clips holding the insulation in place will absolutely melt in the intense heat of an engine fire. However, this is simply a property of plastic—it's a consequence of the fire, not an intentional design feature. If it were a safety system, manufacturers would likely use a more reliable release mechanism.
  • Ineffective Smothering: Even if the blanket drops, it would be a highly ineffective way to smother an engine fire. An engine bay is not a flat, sealed container. It's full of complex shapes, open spaces, and has constant airflow from the grille and underside of the car. A flimsy blanket dropping on top would not be able to cut off the oxygen supply needed to extinguish the fire.
ATestBishop
Alex
Walnut Creek, CA
2024 Ford Ranger XL
Let's not discount the idea that like the trunk lid liners, the hood when open really does look more pleasing to the eye with a liner, perhaps because the many structural contours and openings under the hood just look "busy"
I asked AI:
Maybe the usage has changed since the time that it was used that way?
I grew up driving carb'd vehicles and many carb fires were put out when the under hood insualtion feel on it and smothered the fire.
I now i very very rarely see vehicles on the side of the road with the hood open and the insulation on the engine instead of the hood. With fuel injection becoming the only type of fuel delivery system, and not tbi, direct injection and port injection, maybe fire suppresion is no longer required as engine fires are a thing of thr past?
I used to stop and help people on the side of the highway who had an engine fire once or twice a year but that has not happened in probably 20 years.
daytoncarter
Dayton
I think on a proportional basis, EVs are more likely to burn compared to gas cars. Although I also note car fires are less common, I know many cars are also moving to electric power steering, so one less thing to leak. But, my Genesis has an open recall for a turbo oil feed line which can cause a fire, so various mechanisms contribute.
waffleso_0
Oakland California
24 Ranger XLT 2.7L V6
Yeah for a MSRP of $227 for the part I think I'll pass. Fortunately I made my own for free that surpasses the quality of the OEM specific part and still uses a Ford/Madza OEM part. As far as whoever at Ford made the decision, I believe they were wrong to not put it on every Ranger as standard
Can you link to the product you're referring to?
ATestBishop
Alex
Walnut Creek, CA
2024 Ford Ranger XL
Certainly I can. I was able to start by making my own cardboard template and then brought that with me to source a used part to modify custom which happened to be from a 08 Mazda 3 as I wanted something Ford quality and associated if possible. Insulator - Ford (N1WZ-16738-B)
2024-2025 Ford Ranger - n1wz16738b
https://ford.oempartsonline.com/oem-parts/ford-insulator-n1wz16738b
DexterTheDog
Southern California
2015 Subaru Forester. 2025 Azure Grey XLT
I had to drop my truck off at the dealer today to repair a small shipping ding. While I was there I asked about the insulation from one of the service managers. He stated it is not included in the XLT's but was on the older ones. I didn't get a chance to have him elaborate on "older". I'll see if I can get an second opinion from another service manager when I pick it up.
Ryder66
Ryder66
Chris
Thanks for the update. I don't understand why it's no longer included. I guess the engine is no longer noisy or doesn't generate heat. Hopefully you can get more out of someone else.
bigb
Tucson
2025 Ranger 2.7
They might be trying to cut costs due to the tariffs. I read where the tariffs actually hurt Ford more than some of the import cars because even though they build here, they import parts which have higher tariffs than whole cars.
DexterTheDog
Southern California
I picked up my truck from the dealer yesterday and checked with another service manager, and was told the same thing as before: it's not included in newer builds. Found a video walkthrough from 3 months ago (about 50 sec into it 2025 Ford Ranger XLT Review | POV Test Drive + Full Walkaround ) that shows it not installed. Looks like Ford decided to save a few $$ and not include it. I'll probably start looking for one on sale/discounted and install it myself. Now that I know they used to be included, its kinda bugging me not seeing it when I open the hood. lol
